[mapguide-internals] MapGuide open source builds - Linux & Cmake
Jackie Ng
jumpinjackie at gmail.com
Thu Oct 9 01:09:19 EDT 2008
Building MapGuide in Linux is just painful right now, the last time I was
able to build MapGuide without major issues was when the trunk was in
pre-2.0 revision.
Even then, you had to get all the build steps correct without fail, or bad
things may (and do) happen.
I'm all for improvements to the build system on the linux side (at least).
- Jackie
zspitzer wrote:
> Just breaking the Cmake stuff out into a seperate thread
> Based on the feedback from the AD developers about sticking with the VS
> build system on Windows, what do people think about the Cmake option on
> linux
>>From the sound of things if we go ahead with this, we are going to
> keep the existing
> build system for windows and adopt cmake for any other platforms
> Can we add Helio's stuff to the tree and run with two build systems?
> Helio, the existing full build with all the embedded thirdparty stuff
> works currently?
> If it does and we don't have to worry about the issues like the db 4.2
> you mentioned
> the 2.1 release could be a good opportunity to test this out as I
> assume quite a
> few people are going to be trying to compile 2.1 on linux
> I am prepared to be a crash test dummy on this...
> z
> On Thu, Oct 9, 2008 at 3:58 AM, Helio Chissini de Castro <helio at kde.org>
> wrote:
>> On Quarta 08 Outubro 2008 13:22:26 Traian Stanev wrote:
>>> Yes, I did a 64 bit FDO build using externally installed dependent third
>>> party libraries last week on Ubuntu, and it worked out pretty well. I
>>> did
>>> not compile all providers though, so I can't speak for all the
>>> dependencies, just xerces/xalan and the like.
>>> Traian
>> Hi guys, i'm on a quick trio on US and Zac ping me about the discussion.
>> For 64 bits, i already have cake build working with most of the third
>> party
>> dependencies sorted.
>> I have mapguide too, with some small issue, which is DB 4.2
>> Maptguide relies in DB 4.2, most of distros have DB 4.5 or 4.6 apache
>> build (
>> apr things ), which lead me to try compile mapguide with a recent Db
>> The problem is even been API compatible, db segfaults everytime in the
>> database creation, and i had no time to solve the issue.
>> To fix my problem i recompiled my apache rpm with exactly same db
>> mapguide
>> have.
>> As Jason commented about the frustration of the whole RFC, to not kept
>> too
>> much out of sync, i did rpm version for current fdo, and mapguide, but
>> only 32
>> bits, as pristine as possible.
>> As soon i back from US i can answer other questions with more time
>> []'s
>> KDE Project
>> Brasil and South America Primary Contact
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
View this message in context: http://n2.nabble.com/MapGuide-open-source-builds---Linux---Cmake-tp1308409p1308715.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
