[mapguide-internals] mapguide 2 trunk cmake patches
andinstructions - with links instead of patches
Jason Birch
Jason.Birch at nanaimo.ca
Thu Oct 23 15:05:47 EDT 2008
You I wonder if you can get around this by reverting
Common/Geometry/GeometryExceptionDef.h
This file was changed by the patch to be compatible with GEOS-3, which
(I think) is not available in backports. More on this to follow...
Jason
-----Original Message-----
Subject: Re: [mapguide-internals] mapguide 2 trunk cmake patches
[ 53%] Building CXX object
Common/Foundation/CMakeFiles/MgFoundation.dir/FoundationBuild.cpp.o
Linking CXX shared library libMgFoundation.so
[ 53%] Built target MgFoundation
Scanning dependencies of target MgGeometry
Common/Geometry/CMakeFiles/MgGeometry.dir/GeometryBuild.cpp.o
In file included from
/home/zac/mapguide-2.0.2/Common/Geometry/GeometryBuild.cpp:61:
/home/zac/mapguide-2.0.2/Common/Geometry/GeosUtil.cpp: In static
member function 'static bool MgGeosUtil::Contains(MgGeometry*,
MgGeometry*)':
/home/zac/mapguide-2.0.2/Common/Geometry/GeosUtil.cpp:75: error:
expected type-specifier
expected unqualified-id before '::' token
expected `)' before '::' token
expected `{' before '::' token
expected initializer before ')' token
expected primary-expression before 'catch'
expected `;' before 'catch'
member function 'static bool MgGeosUtil::Intersects(MgGeometry*,
MgGeometry*)':
/home/zac/mapguide-2.0.2/Common/Geometry/GeosUtil.cpp:112: error:
On Fri, Oct 24, 2008 at 5:52 AM, Zac Spitzer <zac.spitzer at gmail.com>
wrote:
> i got a little further
> Linking CXX static library libMgSecurity.a
> [ 53%] Built target MgSecurity
> In file included from /usr/include/ace/ACE_export.h:11,
> from /usr/include/ace/Sock_Connect.h:19,
> from /usr/include/ace/INET_Addr.h:17,
> from
> /home/zac/mapguide-2.0.2/Common/Foundation/Foundation.h:46,
> from
/home/zac/mapguide-2.0.2/Common/Foundation/Data/BatchPropertyCollection.
cpp:18,
> from
> /home/zac/mapguide-2.0.2/Common/Foundation/FoundationBuild.cpp:21:
> /usr/include/ace/config-lite.h:71:7: error: #error _REENTRANT has to
be defined!
cpp:18,
> from
> /home/zac/mapguide-2.0.2/Common/Foundation/Foundation.h:198:2: error:
> #error Please define ACE_HAS_THREAD_SAFE_ACCEPT
> make[2]: ***
[Common/Foundation/CMakeFiles/MgFoundation.dir/FoundationBuild.cpp.o]
> Error 1
> make[1]: *** [Common/Foundation/CMakeFiles/MgFoundation.dir/all] Error
2
> make: *** [all] Error 2
> On Fri, Oct 24, 2008 at 5:42 AM, Helio Chissini de Castro
<helio at kde.org> wrote:
>> On Quinta 23 Outubro 2008 16:30:12 Zac Spitzer wrote:
>>> Scanning dependencies of target MgFoundation
cpp
>>>:18, from
>>> /home/zac/mapguide-2.0.2/Common/Foundation/Foundation.h:46:27:
error:
>>> ace/INET_Addr.h: No such file or directory
>> ACE library.
>> in Debian/Ubuntu is libace-dev
>> Seens like you get quicly how to play with the cmake Find* files,
which
>> considering two days only, makes me happy because we just exchanged 2
emails
>> KDE Project
>> Brasil and South America Primary Contact
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
More information about the mapguide-internals
