[mapguide-internals] mapguide 2 trunk cmake patches
andinstructions - with links instead of patches
Jason Birch
Jason.Birch at nanaimo.ca
Thu Oct 23 15:07:02 EDT 2008
I also included the hardy backports by uncommenting two lines in
/etc/apt/sources.list.
I added packages like apache2, php5, libgdal1-dev, and a bunch of
others; we should probably start a wiki listing the prerequisites and
required versions.
Rather than adding the fdo install location to the .cmake file, I
specify it on the command line:
cmake -D FDO_INCLUDE_DIR:PATH=/usr/local/fdo-3.3.0/include -D
FDO_LIBRARY:FILEPATH=/usr/local/fdo-3.3.0/lib ..
If you run into a missing dependency outside of the .cmake file's search
path, you can run:
cmake -LA ..
Which will give you a list of current settings for cache entries that
you can specify on the command line, including "UNDEFINED"
something-or-other when they couldn't be found.
Source files that were patched for the build follow. I believe that you
can revert most of these if you are using versions of the libraries
equivalent to what are distributed with MapGuide (or even pointing to
the mapguide oem builds for these components with -D cache entries).
BuildTools/WebTools/IMake/IMake.cpp
Add include for <cstring>
BuildTools/WebTools/IMake/SimpleXmlParser.cpp
BuildTools/WebTools/IMake/SimpleXmlParser.h
Add include for <cstdlib>
Common/Geometry/GeometryExceptionDef.h
Changes for Geos 3
Common/MdfParser/SAX2Parser.h
Add include for <xercesc/sax2/Attributes.hpp>
Common/Renderers/AGGRenderer.cpp
Commented out triangle cap
Oem/jsoncpp/src/lib_json/json_reader.cpp
Removed includes for <stdio.h. and <assert.h>, added <cstdio>,
<cstring>, <cassert>
Oem/jsoncpp/src/lib_json/json_value.cpp
Oem/jsoncpp/src/lib_json/json_writer.cpp
Server/src/Services/Feature/FilterUtil.h
Updated to Xerces 2.8
Server/src/Services/Feature/ServerDescribeSchema.h
Added include for "CacheManager.h"
Jason
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac
Spitzer
Sent: Thursday, October 23, 2008 11:30
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] mapguide 2 trunk cmake patches
firstly, I gotta say from a bit of playing with CMake I'm impressed :)
things i had to do on ubuntu 8.04
add hardy-backports to sources
sudo apt-get install cmake libboost // for 2.60, default was 2.46
this needs a big list of packages to be installed :) i will pull the
list, i'm sure i added
more than i needed
the path for php5 on ubuntu is /usr/local/include/php5, I don't think
the PHP5_LIBRARY is referenced by cmake aside from the setup and test
had to add the /usr/local/fdo-3.3.0/include/ and
/usr/local/fdo-3.3.0/lib/
to the search path for FindFDO.cmake
for apache /usr/include/apr-1.0 ( rather than /usr/include/apr-1)
i got stuck here and I'm tired in 5;29 am in oz
Scanning dependencies of target MgFoundation
[ 53%] Building CXX object
Common/Foundation/CMakeFiles/MgFoundation.dir/FoundationBuild.cpp.o
In file included from
/home/zac/mapguide-2.0.2/Common/Foundation/Data/BatchPropertyCollection.
cpp:18,
from
/home/zac/mapguide-2.0.2/Common/Foundation/FoundationBuild.cpp:21:
/home/zac/mapguide-2.0.2/Common/Foundation/Foundation.h:46:27: error:
ace/INET_Addr.h: No such file or directory
z
On Thu, Oct 23, 2008 at 10:45 PM, Helio Chissini de Castro
<helio at kde.org> wrote:
> On Quinta 23 Outubro 2008, Zac Spitzer wrote:
>> ok, i'm having a bit of trouble applying the patch
>> i have checked 2.0.2 out into /home/zac/mapguide-2.0.2
>> what's the patch syntax required?
>> z
> HI
> cd mapguide-2.0.2
> patch -p1 < cmake-mg202.diff
> Jason reported that in case of Ubuntu, he was missing libphp5_common (
the PHP
> test look for this library ), and looks like php from Ubuntu is not
compiled
> to have this shared library, so probably you can bypass this test for
now, in
> main CMakeLists.txt
> []'s
> KDE Developer
> Brasil/South America Primary Contact
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
More information about the mapguide-internals
