[mapguide-internals] mapguide 2 trunk cmake patches
andinstructions - with links instead of patches
Helio Chissini de Castro
helio at kde.org
Thu Oct 23 16:35:11 EDT 2008
On Quinta 23 Outubro 2008 17:34:22 Helio Chissini de Castro wrote:
> n Quinta 23 Outubro 2008 17:07:02 Jason Birch wrote:
> > I also included the hardy backports by uncommenting two lines in
> > /etc/apt/sources.list.
> > I added packages like apache2, php5, libgdal1-dev, and a bunch of
> > others; we should probably start a wiki listing the prerequisites and
> > required versions.
> > Rather than adding the fdo install location to the .cmake file, I
> > specify it on the command line:
> > cmake -D FDO_INCLUDE_DIR:PATH=/usr/local/fdo-3.3.0/include -D
> > FDO_LIBRARY:FILEPATH=/usr/local/fdo-3.3.0/lib ..
> > If you run into a missing dependency outside of the .cmake file's search
> > path, you can run:
> > cmake -LA ..
> > Which will give you a list of current settings for cache entries that
> > you can specify on the command line, including "UNDEFINED"
> > something-or-other when they couldn't be found.
> > Source files that were patched for the build follow. I believe that you
> > can revert most of these if you are using versions of the libraries
> > equivalent to what are distributed with MapGuide (or even pointing to
> > the mapguide oem builds for these components with -D cache entries).
> > BuildTools/WebTools/IMake/IMake.cpp
> > Add include for <cstring>
> > BuildTools/WebTools/IMake/SimpleXmlParser.cpp
> > BuildTools/WebTools/IMake/SimpleXmlParser.h
> > Add include for <cstdlib>
> > Common/Geometry/GeometryExceptionDef.h
> > Changes for Geos 3
> > Common/MdfParser/SAX2Parser.h
> > Add include for <xercesc/sax2/Attributes.hpp>
> > Common/Renderers/AGGRenderer.cpp
> > Commented out triangle cap
> > Oem/jsoncpp/src/lib_json/json_reader.cpp
> > Removed includes for <stdio.h. and <assert.h>, added <cstdio>,
> > <cstring>, <cassert>
> > Oem/jsoncpp/src/lib_json/json_value.cpp
> > Oem/jsoncpp/src/lib_json/json_writer.cpp
> > Server/src/Services/Feature/FilterUtil.h
> > Updated to Xerces 2.8
> > Server/src/Services/Feature/ServerDescribeSchema.h
> > Added include for "CacheManager.h"
> > Jason
> > -----Original Message-----
> > From: mapguide-internals-bounces at lists.osgeo.org
> > [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac
> > Spitzer
> > Sent: Thursday, October 23, 2008 11:30
> > To: MapGuide Internals Mail List
> > Subject: Re: [mapguide-internals] mapguide 2 trunk cmake patches
> > firstly, I gotta say from a bit of playing with CMake I'm impressed :)
> > things i had to do on ubuntu 8.04
> > add hardy-backports to sources
> > sudo apt-get install cmake libboost // for 2.60, default was 2.46
> > this needs a big list of packages to be installed :) i will pull the
> > list, i'm sure i added
> > more than i needed
> > the path for php5 on ubuntu is /usr/local/include/php5, I don't think
> > the PHP5_LIBRARY is referenced by cmake aside from the setup and test
> > had to add the /usr/local/fdo-3.3.0/include/ and
> > /usr/local/fdo-3.3.0/lib/
> > to the search path for FindFDO.cmake
> > for apache /usr/include/apr-1.0 ( rather than /usr/include/apr-1)
> > i got stuck here and I'm tired in 5;29 am in oz
> > Scanning dependencies of target MgFoundation
> > [ 53%] Building CXX object
> > Common/Foundation/CMakeFiles/MgFoundation.dir/FoundationBuild.cpp.o
> > In file included from
> > /home/zac/mapguide-2.0.2/Common/Foundation/Data/BatchPropertyCollection.
> > cpp:18,
> > from
> > /home/zac/mapguide-2.0.2/Common/Foundation/FoundationBuild.cpp:21:
> > /home/zac/mapguide-2.0.2/Common/Foundation/Foundation.h:46:27: error:
> > ace/INET_Addr.h: No such file or directory
> > z
> > On Thu, Oct 23, 2008 at 10:45 PM, Helio Chissini de Castro
> > <helio at kde.org> wrote:
> > > On Quinta 23 Outubro 2008, Zac Spitzer wrote:
> > >> ok, i'm having a bit of trouble applying the patch
> > >> i have checked 2.0.2 out into /home/zac/mapguide-2.0.2
> > >> what's the patch syntax required?
> > >> z
> > > HI
> > > cd mapguide-2.0.2
> > > patch -p1 < cmake-mg202.diff
> > > Jason reported that in case of Ubuntu, he was missing libphp5_common (
> > the PHP
> > > test look for this library ), and looks like php from Ubuntu is not
> > compiled
> > > to have this shared library, so probably you can bypass this test for
> > now, in
> > > main CMakeLists.txt
> > > []'s
> > > KDE Developer
> > > Brasil/South America Primary Contact
> > > _______________________________________________
> > > mapguide-internals mailing list
> > > mapguide-internals at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/mapguide-internals
KDE Project
Brasil and South America Primary Contact
More information about the mapguide-internals
