[mapguide-internals] Sheboygan package
sergi nistal serginistal at hotmail.com
Thu Sep 4 14:42:25 EDT 2008
Hi, the problem was that I used FireFox3.
Now I have other problems (see images.rar):
1- The result of the image 'mapagent1.jpg' is 'mapagent2.jpg', it´s ok (argument out of range)?
2- Warning in 'find address' (image with the same name). It works but it returns this warning:
Warning:Call-timepass-by-reference has been deprecated; If you would like topass it byreference, modify the declaration of xml_set_object(). Ifyou would liketo enable call-time pass-by-reference, you cansetallow_call_time_pass_reference to true in your INI fileinC:\MAPGUIDE2\mapguide-2.0.1\Web\src\phpviewersample\findaddress\kd_xmlrpc.phponline 83 (and other lines)
3- Problem in 'query features'.Images'query features1.jpg' and 'query features2.jpg'. In the box'Layer' onlyappears '>', in the box 'Property' appears nothing, ...
4- The same problem that 3 in 'theme player'.
5- To use 'plot as DWF' (image 'plot.jpg') I need Autodesk DWF Viewer, don´t?
Thanks.
> Date: Thu, 4 Sep 2008 09:20:31 +0200
> From: ks at geograf.dk
> To: mapguide-internals at lists.osgeo.org
> Subject: Re: [mapguide-internals] Sheboygan package
> It appears that you images got lost in the mail.
> The usual errors are:
> 1. Downloading the sample data with IE, renames the files to .zip,
> making them unavalible in MapGuide
> 2. Viewing a map with FireFox3 only displays the background.
> If there is no 'Samples/Sheyboygan' folder after the package restore,
> the problem is with the package restore.
> If you can view the demo solution, but with no actual map, you have
> restored the package,
> but at most likely using Firefox3 to view it, but have not  patched the
> server.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> sergi nistal skrev:
> > Hi,
> > I´m installing a debug version of Mapguide 2.0.1 with FDO 3.3.1 on Windows Vista from source code.
> > I´m 'Installing Sample Data and Sample Applications' (document with the same name) and when I make image 1
> > the result is image 2 (paragraph 'Instructions for Loading the Sample Data on the Server'), the result of
> > http://localhost/mapguide/phpviewersample/ajaxtiledviewersample.php is image 3 and the result of
> > http://localhost/mapguide/phpviewersample/ajaxviewersample.php is image 4 (paragraph 'Setting up Sample
> > Applications (PHP) with Apache'), Is everythong ok? Should not bring up a map instead of the whole
> > orange background? Should interrogations appear beside the section of the layers
> > (Islands, Hydrography, ...)? and finally the result of http://localhost/mapguide/webstudio/index.html is
> > image 5, Should not appear libraries Sheboygan in section 'Site Explorer'?
> > If you need other data, please contact me. Thank you very much.
> >> Date: Tue, 2 Sep 2008 21:51:01 +0200
> >> What is the problem with the Sheboygan package?
> >> sergi nistal skrev:
> >>> Hi,
> >>> Is there any package of example apart Sheboygan.mgp to prove mapguide? The package Sheboygan don´t work for me.
> >>> Thanks
> >>> _________________________________________________________________
> >>> Llega la nueva temporada. Consulta las nuevas tendencias en MSN Estilo
> >>> http://estilo.es.msn.com/moda/_______________________________________________
> >>> mapguide-internals mailing list
> >>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Prueba los prototipos de los últimos en MSN Motor
http://motor.es.msn.com/
More information about the mapguide-internals mailing list
