[mapguide-internals] MapGuide RFC 53 Review
Steve Dang steve.dang at autodesk.com
Mon Sep 15 13:34:20 EDT 2008
Hi list,
I've not heard any comment/suggestion on this issue so I assume we want to stick with the simple approach of using the "." delimiter for class names. Please let me know if there is a problem.
Thanks,
Steve.
-----Original Message-----
Sent: Tuesday, August 19, 2008 5:10 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] MapGuide RFC 53 Review
I have discussed with our MapGuide Development team about an alternative way to format/encode a comma delimited string.
Here is our proposal: The class name will be enclosed by double quotes if it contains any comma, and any double quote inside this class name will be double quoted.
For example, for the following list of class names:
Class1,
Class2
Class3"
",Class4
The comma delimited string of these class names will look like:
"Class1,",Class2,Class3",""",Class4"
Comments/suggestions?
Thanks,
Steve.
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Steve Dang
Sent: Monday, August 18, 2008 2:15 PM
Comma or tab was one of my choices I had in mind but unfortunately they are not reserved characters for class names because FDO separates schema and class name by ":", and class and property name by ".".
Thanks,
Steve.
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Monday, August 18, 2008 12:59 PM
Subject: Re: [mapguide-internals] MapGuide RFC 53 Review
Is there a reason for using a period and not a comma to seperate class names?
CLASSNAMES=Class1.Class2.Class3
  vs
CLASSNAMES=Class1,Class2,Class3
z
On Tue, Aug 19, 2008 at 4:39 AM, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
> Can't comment on the implementation, but this is an important addition
> to MapGuide when interacting with DBMS-based feature sources.
> I'm assuming that you will be testing the command capabilities to
> determine which providers to call the old mechanism for?
> Jason
> From: Steve Dang
> Subject: [mapguide-internals] MapGuide RFC 53 Review
> Please review MapGuide RFC 53 (DescribeSchema, DescribeSchemaAsXml,
> GetSchemas and GetClasses API Enhancements),
> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc53, and send any comment
> to this mail list.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
More information about the mapguide-internals mailing list
