[mapguide-internals] MapGuide Open Source 2.0.2 posted
Zac Spitzer zac.spitzer at gmail.com
Tue Sep 16 04:51:39 EDT 2008
Looks really good so far, I have successfully seeded an entire map on xp using
managed sdfs without the server falling over or producing a single
error :) 30k tiles
The memory usage hovered around 60-63 mb, whereas with 2.0.1 it would
blow out to 600mb+ before crashing..
I did make two tweaks to the standard config before i tested which where
CacheSize                          = 1000 (was 100)
#DataConnectionPoolExcludedProviders= OSGeo.SDF,OSGeo.SHP
I quickly tried out a GDAL raster layer and it also just worked
without any errors
Regards
Zac
On Tue, Sep 16, 2008 at 5:00 PM, Tom Fukushima
<tom.fukushima at autodesk.com> wrote:
> To MapGuide Internals,
> The MapGuide Open Source 2.0.2 candidate installers and tar file have been posted to http://download.osgeo.org/mapguide/releases/2.0.2/.  Give it a try if you can before we formally announce it.
> Thanks
> Tom
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
More information about the mapguide-internals mailing list
