[mapguide-internals] MapGuide Open Source 2.0.2 posted
    Kenneth Skovhede, GEOGRAF A/S
    ks at geograf.dk
    Tue Sep 16 05:38:21 EDT 2008
I have tested it briefly, and it seems to install smoothly.
I was able to import my entire site, and it appears to be working.
Regards, Kenneth Skovhede, GEOGRAF A/S
Zac Spitzer skrev:
> I did manage to get the mapguide server completely stuck with GDAL,
> tho i think it's slightly
> more stable than before
> z
> On Tue, Sep 16, 2008 at 6:51 PM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
>> Looks really good so far, I have successfully seeded an entire map on xp using
>> managed sdfs without the server falling over or producing a single
>> error :) 30k tiles
>> The memory usage hovered around 60-63 mb, whereas with 2.0.1 it would
>> blow out to 600mb+ before crashing..
>> I did make two tweaks to the standard config before i tested which where
>> CacheSize                          = 1000 (was 100)
>> #DataConnectionPoolExcludedProviders= OSGeo.SDF,OSGeo.SHP
>> I quickly tried out a GDAL raster layer and it also just worked
>> without any errors
>> Regards
>> Zac
>> On Tue, Sep 16, 2008 at 5:00 PM, Tom Fukushima
>> <tom.fukushima at autodesk.com> wrote:
>>> To MapGuide Internals,
>>> The MapGuide Open Source 2.0.2 candidate installers and tar file have been posted to http://download.osgeo.org/mapguide/releases/2.0.2/.  Give it a try if you can before we formally announce it.
>>> Thanks
>>> Tom
>>> mapguide-internals mailing list
>>> mapguide-internals at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
>> Zac Spitzer -
>> http://zacster.blogspot.com (My Blog)
>> +61 405 847 168
More information about the mapguide-internals
