[mapguide-internals] SELECTFEATURES via mapagent and null values
Tom Fukushima
tom.fukushima at autodesk.com
Tue Sep 23 13:44:54 EDT 2008
That is not the expected behavior.
My guess is that the web tier is throwing an exception when it tries to convert the result to XML.
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Tuesday, September 23, 2008 10:25 AM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] SELECTFEATURES via mapagent and null values
Using the Sample Symbolization dataset
Do a SELECTFEATURES call via the mapagent test pages with the following
parameters:
Resource ID:
Library://Samples/Symbolization/Highways/Data/Interstate.FeatureSource
Class Name: interstate
An exception will be thrown with the message: "value for PREFIX property is
null"
Is this expected behaviour?
- Jackie
View this message in context: http://n2.nabble.com/SELECTFEATURES-via-mapagent-and-null-values-tp1112902p1112902.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
