[mapguide-internals] Is 2.1 going to support 64-bit
Helio Chissini de Castro helio at kde.org
Wed Apr 1 06:05:16 EDT 2009
On Terça-feira 31 Março 2009, Bruce Dechant wrote:
> Helio,
> Did you get it working on Windows with 5.4? Reason I ask is that when I
> built with ACE 5.4 for Windows the IP address was switched, ie: 144.111.1.2
> would end up being transposed into 2.1.111.144. If I entered the IP address
> backwards in the webconfig.ini it worked. When I upgraded to ACE 5.6 this
> bug went away on Windows.
> What issues are you seeing with dbxml? I have been using 64bit server on
> Windows for several days now without issue.
> Thanks,
> Bruce
Hi Bruce
Sorry if was not clear. I was talking about linux, not windows. Since i build
mapguide using an internal cmake buildsystem i can compile using the most
possible external shared libraries, allowing to me using a patched ACE version
and now a 5.6.
The real issue in linux is dbxml. You can't compile his main dependency, db,
in a different version or shared one in x86_64 without have a complete
instability.
In special, the initial constructor of databases is crashing often invoking a
big segfault. I know it is a dbxml + db issue, but never found time to debug
it. Exactly same build on 32 bits works perfect :-(
[]'s
KDE Developer
Brasil/South America Primary Contact
More information about the mapguide-internals mailing list
