[mapguide-internals] RE: EPSG:3785 or with CS-Map?
Bruce Dechant bruce.dechant at autodesk.com
Wed Apr 1 16:27:30 EDT 2009
How would one go about adding this EPSG code as a supported system?
Thanks,
Bruce
________________________________________
From: mapguide-internals-bounces at lists.osgeo.org [mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Hugues Wisniewski
Sent: Wednesday, April 01, 2009 2:25 PM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] RE: EPSG:3785 or  with CS-Map?
Hi again,
Let me rephrase that one a bit.
CsMap doesn't have a system in its dictionaries for this EPSG code but if the WKT is provided to the API in input, a custom system will be created.
Since MapGuide understands such systems and doesn't need to have a system physically present in its dictionary to be able to work, MapGuide can work with this WKT.
If instead of the WKT expression the EPSG code is used to initialize the underlying MgCoordinateSystem API, the initialization will fail.
Hugues
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Hugues Wisniewski
Sent: Wednesday, April 01, 2009 12:29 PM
Hi Jason,
This system is currently not supported by CsMap
Hugues
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Wednesday, April 01, 2009 11:56 AM
To: 'MapGuide Internals Mail List'
Subject: [mapguide-internals] EPSG:3785 or with CS-Map?
Brian asked a question about using the "Google Maps Projection" with MapGuide.  I was hoping that CS-Map would support EPSG:3785 natively, but I can't get it to work with the latest 2.1 installer using any of the CS web tier test pages.  Here's the definition:
http://spatial-reference.org/ref/epsg/3785/ogcwkt/
Is there a projection code for this?  Do I need to add some kind of lookup?  Because Fusion 2.0 supports multiple map layers, I'd imagine that many users will want to have a Google Maps base layer.  Ideally, we could bundle this CS definition to help these users.
Thanks,
Jason
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
