[mapguide-internals] Exception Handling for Memory limitations + Patch for #480 & #520
Walt Welton-Lair walt.welton-lair at autodesk.com
Thu Apr 2 23:40:05 EDT 2009
Hi UV,
I worked on ByteSink::ToFile earlier today to fix ticket 480 and made most of the same changes as you.  Was planning on submitting tomorrow.  I didn't do the halving of the memory allocation, but what you did looks reasonable.  Also, in my change I delete the file if any exception is encountered - in your case you delete it only if it's empty.  Both seem like reasonable choices.  When an exception occurs it's possible the file got written out completely and is valid, but it's also possible it was only partially written and therefore not valid.  Any more thoughts on that?
One other thing - I realize you're frustrated at times working with the overall code.  Some parts are not documented as well as they could be, some parts are not coded as well as they could be.  But comments like "I am just slowly getting fed up reading a lot of code that has clearly
not been written to be understood by other people" are not going to help.  Despite the code not being optimal, a lot of people put a lot of work into this code and so in a way you're bashing them.  Instead, channel your frustration to actually help improve the code.  Like submitting these patches - these are very much appreciated.
Walt
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of UV
Sent: Thursday, April 02, 2009 11:17 PM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] Exception Handling for Memory limitations + Patch for #480 & #520
Hi there,
I am trying to make the mgserver behave in the case of limited memory..
We are using a massive map for our client and the server keeps on
falling over. (did not reproduce in 2.0.2)
I followed the trace from StylizeLayerinto the SimpleSDFReader which
fails with a (ret != SQLiteDB_OK)
This interface to the underlying SQLiteTable::get call does not do
exception handling so we have lost the underlying reason.....
I assume its a failed malloc somewhere as I am investigating out of
memory behaviour.
Furthermore the MappingUtil::StylizeLayers method simply eats up the
exception.
I am not sure if this is really the desired behaviour. Maybe this should
be examinated in more detail.
not been written to be understood by other people.
So other approaches are needed.
== Smart Handling of Out of Memory Exceptions ==
I suggest to wrap all memory allocation deeper in the code into retry
loops with a time delay doubling at each repetition (like CSMA/CD).
Another option used in my ByteSink patch simply decreases the allocated
buffer as it can in this particular case.
This should increase server stability massively as memory is used and
returned a lot in this multi-threaded server.
This should provide a way for the halted threads to get the memory they
need at a later point in time.
I think waiting is a realistic engeering approach to solve the OoM
problem.  (I learned this style while coding on a realtime audio engine :)
== Patch for #480 #520 ==
The patch cleans up the file handle and removes empty files. Furthermore
an intelligent exception handler uses a buffer of an available size if
1MB is not available anymore.
(1MB looks like a quite a hefty estimation of the needed size in the
first place.....)
More information about the mapguide-internals mailing list
