[mapguide-internals] Mapguide -> FDO dependencies?
UV
uvwild at gmail.com
Sat Apr 4 21:53:16 EDT 2009
Thanks for the clarification.
The fdo roadmap says there is no 3.4 branch yet which means we dont have
a very stable build situation in the moment.
Building mapguide trunk vs fdo trunk should work but its a moving target....
This pretty much confirms my build experience.
Jason Birch wrote:
> I agree that the dependancies should be documented, probably on the official release page for releases, or on the milestone page or a wiki page for future releases.
> MapGuide will be using FDO 3.4 for the 2.1 release, so until 2.1 is branched you should either be building against the FDO 3.4 branch or, once FDO 3.4 is released, that tag.
> I'm pretty sure that MapGuide 2.2 will be targetting FDO 3.5, so once we branch 2.1 you would want to re-point to FDO trunk.
> My suggestion to contact the FDO team was entirely about their trunk creating a gdal14.dll; I have no clue why it would do that.
> Jason
> ----- Original Message -----
> From: mapguide-internals-bounces at lists.osgeo.org <mapguide-internals-bounces at lists.osgeo.org>
> To: MapGuide Internals Mail List <mapguide-internals at lists.osgeo.org>
> Sent: Sat Apr 04 16:39:34 2009
> Subject: Re: [mapguide-internals] Mapguide -> FDO dependencies?
> I am not sure if there are dependencies from mapguide to FDO that the
> fdo people would know about it.
> I would think if its the mapguide code using FDO libs the mapguide
> project should be clear about the dependencies.
> Which are they and where to find them please?
> This is essential configuration management and it should be clear for
> everyone for things to work.
> So if I am building the trunk should I be building against fdo trunk?
> That was my assumption.
> Is this really not written down anywhere?
> Especially if suddenly new library versions show up and there is no way
> to check what this is about except this list.
> Please!!!
> Jason Birch wrote:
>> The best place to ask about this is fdo-internals mailing list (copied; UV, you'll need to subscribe to reply).
>> I'm surprised that it outputs a gdal14.dll. Was that using a Debug or Release target? I've been using the FDO release candidate SDKs for the installer builds, so wouldn't have noticed this.
>> I think that MapGuide trunk (at least prior to our 2.1 branch) should probably be building against the fdo 3.4 branch.
>> Jason
>> -----Original Message-----
>> From: UV
>> Sent: March-31-09 10:22 PM
>> Subject: [mapguide-internals] FDO dependencies?
>> The latest FDO trunk builds a gdal14.dll
>> however, gdal16.dll seems to be the version used for FDO 3.4.0
>> whats the story please?
>> is there a place to find out about such things?
>> If not we need one!
>> cheers,
>> UV
>> mapguide-internals mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
