[mapguide-internals] Mapguide -> FDO dependencies?
Tom Fukushima
tom.fukushima at autodesk.com
Sun Apr 5 11:40:32 EDT 2009
Hi UV,
Since you have built things most recently from trunk and followed whatever instructions we have on the trac site, you may be best qualified to tell us which page you would have expected the information on. Did you find any page where it would have been best to have that information?
BTW, assuming that MGOS trunk builds against FDO trunk should be good.
Thanks
Tom
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of UV
Sent: Saturday, April 04, 2009 5:40 PM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] Mapguide -> FDO dependencies?
I am not sure if there are dependencies from mapguide to FDO that the
fdo people would know about it.
I would think if its the mapguide code using FDO libs the mapguide
project should be clear about the dependencies.
Which are they and where to find them please?
This is essential configuration management and it should be clear for
everyone for things to work.
So if I am building the trunk should I be building against fdo trunk?
That was my assumption.
Is this really not written down anywhere?
Especially if suddenly new library versions show up and there is no way
to check what this is about except this list.
Please!!!
Jason Birch wrote:
> The best place to ask about this is fdo-internals mailing list (copied; UV, you'll need to subscribe to reply).
> I'm surprised that it outputs a gdal14.dll. Was that using a Debug or Release target? I've been using the FDO release candidate SDKs for the installer builds, so wouldn't have noticed this.
> I think that MapGuide trunk (at least prior to our 2.1 branch) should probably be building against the fdo 3.4 branch.
> Jason
> From: UV
> Sent: March-31-09 10:22 PM
> Subject: [mapguide-internals] FDO dependencies?
> The latest FDO trunk builds a gdal14.dll
> however, gdal16.dll seems to be the version used for FDO 3.4.0
> whats the story please?
> is there a place to find out about such things?
> If not we need one!
> cheers,
> UV
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
