[mapguide-internals] Release Build not working???? Debug build is fine
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Apr 8 13:51:48 EDT 2009
The C-0 just means that you have tiles to the left of the
viewport specified in the MapDefinition, it's not necesarily a bug.
Regards, Kenneth Skovhede, GEOGRAF A/S
UV skrev:
> Hi,
> now for the second time I tried to run my 8GB map sample in a release
> build.
> In the debug build the server renders all tiles just fine.
> When I did the same test with the release build the server created
> only tiles in a single color - no more features....
> (the sea is blue.... the desert is beige) the good news is that its
> deterministic..... the same wrong tiles each time.
> I ran the test suite.... OK 430 tests
> The server INFO Trace.log does not show anything special.
> The server is executed from the exact same location in the default
> installation directory.... I verified the DLL versions....
> No error messages... the access.log shows the error free access to the
> tiles..... but the computed tiles are crap.
> Anyone seen this before?
> Any idea what to look for? As its a release build and the debug
> version is working sorting this out is a challenging task.
> If there were any error messages this would be useful but there aint any.
> PS:
> The server repeatedly creates an additional directory in the tilecache
> called C-0 (as opposed to C0)
> containing also very boring featureless tiles  named 0_-1.png to
> 9_-1.png. This looks like a bug.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
