[mapguide-internals] build script confusion RFC62???
Jason Birch Jason.Birch at nanaimo.ca
Thu Apr 16 13:03:17 EDT 2009
Hi UV,
A MapGuide RFC can't be used to modify the FDO build structure, that needs to be dealt with in the FDO project.  Yes, there is a lot of overlap between the projects, but they are autonomous.  While I am in favour of accommodating an FDO CI process on the MapGuide build server, I think that we should focus on getting the MapGuide CI working first.
I'm not sure that I see the value in making the default installer directory structure mirror the build output's directory structure.  Having release / debug / x86 / x64 in the binaries path doesn't really make a lot of sense to the end user.  I wonder if we can accomplish something similar for non-release builds on the CI machine by passing a public property to msiexec to install the bin files to a different location?
Jason
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of UV
Sent: April-15-09 6:38 PM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] build script confusion RFC62???
Is there a way to initiate as decision process?
or do we have to give up on the automated build because no decision can
be made regarding the result of the build?
This is needed before any changes can be made.
Its not so much todo except to agree on a useful structure for the build
/ deploy process.
In the moment we have a windows installer, a postbuild.mak and a
build.bat plus Linux makefiles all doing similar but slightly different
things.
I think this is a unique opportunity to align some of the
inconsistencies in the build process of mapguide and
improve the experience for future contributions.
Thats exactly whats CI is for..... making sure such inconcistencies will
never happen again.
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
