[mapguide-internals] Release build depending on Visual Studio
installation??
Jason Birch
Jason.Birch at nanaimo.ca
Sun Apr 19 23:09:12 EDT 2009
MapGuide has a dependancy of the MS Visual C++ Runtime, and it has to be the same version (SP, etc) that you compiled with. This is bundled with the installer, but if you install MapGuide manually you will need to download and install it yourself.
Assuming that VS2008 SP1 is installed on the build machine, this is probably the correct package:
http://preview.tinyurl.com/89msaj
I'm guessing that this is the problem because that's the only additional component the installer adds, and the installed Release build works just fine on clean PCs.
Jason
________________________________________
Sent: Sunday, April 19, 2009 7:58 PM
Subject: [mapguide-internals] Release build depending on Visual Studio installation??
I just moved a release build from the build server to a machine without
visual studio installed... NOT WORKING
The release configs in the VS projects seem to need some fixing to make
this work.
Is this a well know problem?
More information about the mapguide-internals
