[mapguide-internals] RE: MG 2.1 beta in svn
Jason Birch
Jason.Birch at nanaimo.ca
Mon Aug 10 11:20:08 EDT 2009
Hi Haris,
If you can, I'd recommend using a later version of the beta which includes some fixes to both MapGuide and the installer:
http://download.osgeo.org/mapguide/testing/
If this isn't possible, you can look at the properties of any of the MapGuide binaries (e.g. mgserver.exe, MgFoundation.dll, etc). The last number in the file version or product version should be the SVN revision number. E.g. for the current test build, the SVN revision is 4114, and the file version number is 2.1.0.4114.
If you want to maintain your copy of the current branch, just copy it to a different folder and then use TortoiseSVN to update the copy to a previous revision #.
Jason
-----Original Message-----
Sent: Monday, August 10, 2009 7:29 AM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] MG 2.1 beta in svn
Our 2.1 branch is not compatible with binaries which are released as MG
2.1 beta. There were changes in branch after binaries were published.
I need help, how can I get version of source code which is used to build
2.1 beta ?
Thank you,
Haris
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
