[mapguide-internals] Apache Service event 3299
pcardinal
pierre.cardinal at sympatico.ca
Tue Aug 18 10:21:16 EDT 2009
Hi Jason,
The problem arises when VS2005 or VS2008 is already installed on the
computer.
Pierre
Jason Birch wrote:
> Haven't seen this before, so not sure what the solution is.
> You could try re-installing the MS VC++ Runtime libraries, but those are
> normally not detected by depends.
> Is J: a locally attached hard drive? Is it possible to try installing
> under C:\Apps or something like that to rule out networking and
> locale-related problems?
> Jason
> -----Original Message-----
> From: pcardinal
> Sent: Monday, August 17, 2009 1:26 PM
> To: mapguide-internals at lists.osgeo.org
> Subject: Re: [mapguide-internals] Apache Service event 3299
> I am on 32-bit. And effectively, depends.exe complains on
> MgHttpHandler.dll
> Error: At least one required implicit or forwarded dependency was not
> found.
> Warning: At least one delay-load dependency module was not found.
> Warning: At least one module has an unresolved import due to a missing
> export function in a delay-load dependent module.
> MSVCR90.DLL Error opening file. Le fichier spécifié est intouvable(2).
> [translation: the file is not found]
> IESHIMS.DLL Error opening file. Le fichier spécifié est intouvable(2).
> What is the solution?
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/Apache-Service-event-3299-tp3452312p3466327.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
