[mapguide-internals] A note about implementation of RFC 79 -
Detailed Exceptions
Tom Fukushima
tom.fukushima at autodesk.com
Tue Aug 25 11:01:28 EDT 2009
Hi All,
Please note that we plan to implement the exception hierarchy part of MGOS RFC 79 for "Detailed Exception" in 2.3 (i.e., after 2.2) stream; the "GetNativeErrorCode" method will be added to 2.2. This is due to resource constraints with respect to testing. If this will cause you an inconvenience please tell me (perhaps something can be worked out). If there are no problems, I will update the RFC with this information.
Information about the corresponding FDO RFC 37 is below.
Thanks
Tom
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
Sent: Tuesday, August 25, 2009 8:29 AM
To: FDO Internals Mail List; MapGuide Internals Mail List
Subject: [mapguide-internals] RE: [fdo-internals] A note about implementation of RFC 37 - Detailed Exceptions
Hi Orest,
There is a corresponding MapGuide RFC to expose the Detailed Fdo Exceptions through the MapGuide API http://trac.osgeo.org/mapguide/wiki/MapGuideRfc79. This work is being done by Autodesk. I do not know if there will be an impact on the MapGuide feature if the detailed exceptions are not exposed.
I am cross posting to the MapGuide Internals list for clarification from the implementers of the MapGuide RFC.
Thanks,
Trevor
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Orest Halustchak
Sent: August 25, 2009 6:46 AM
Subject: [fdo-internals] A note about implementation of RFC 37 - Detailed Exceptions
Regarding FDO RFC 37: http://trac.osgeo.org/fdo/wiki/FDORfc37
The native error code part of this RFC will be done for FDO 3.5, but the additional detailed exceptions will be done for the release after this. Let me know if that will be a problem for anyone.
Thanks,
Orest.
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
