[mapguide-internals] Does the Select Within only work for polygon
Dave Wilson dave.wilson at autodesk.com
Tue Dec 1 10:52:06 EST 2009
SelectWithin is a replication of functionality that existed in MG 6.5. The only documentation is from the 6.5 help which isn't entirely accurate because we didn't replicate the full functionality.
The basic premise is: the user selects one or more polygons (and/or buffers) and wants to find objects "within" those polygons. The current implementation uses an intersection if I am not mistaken so any feature that intersects the polygon should be selected.
I logged 2 defects previously 1223510 and 1223511 regarding the fact that a "within" select (meaning only inside) actually uses intersects which is a bit of a contradiction.
In MG 6.5 we had options for Select Within including selecting objects whose centroid was within the polygon. We never replicated the centroid functionality.
Hopefully that makes things clearer.
Dave
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Buddy Hu
Sent: Monday, November 30, 2009 5:49 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Does the Select Within only work for polygon
Hi Dave,
Do we have any specs or something to describe the SelectWithin feature?
Thanks,
-Buddy
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Tuesday, December 01, 2009 12:24 AM
SelectWithin should work with a polygon or multi-polygon. Whether or not the logic is clean enough to handle a case where more than one type of feature is selected (a polygon and a line for example) is another question.
The 500 error is a bug for sure.
Regards,
Dave
Sent: Monday, November 30, 2009 1:22 AM
Thanks Kenneth!
I think so. It seems that there are some logic error for the selectwithin.php.
Any other comments?
Regards,
-Buddy
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Kenneth Skovhede, GEOGRAF A/S
Sent: Monday, November 30, 2009 4:22 PM
Subject: Re: [mapguide-internals] Does the Select Within only work for polygon
It sounds a like a bug to me.
At least there should not be a "500" error.
Regards, Kenneth Skovhede, GEOGRAF A/S
Buddy Hu skrev:
> Hi There,
> I notice that, the Select within only works for polygon. If there are some other features (such as multipolygon, polyline) selected with polygon, there will be a 500 internal Server Error for selectwithin.php. If there are only multipolygon selected, everything will be cleared after I press the "Done" button.
> I find a description about the "Select Within" in the AJAX Task list home page like this: After you have selected an area, such as a buffer or a polygon on the map, you can select certain features within that area.
> So I want to know, does this Select Within function only work for polygon or buffer? Is this intended?
> If it's no, I want to log a defect for this issue.
> Thanks,
> -Buddy Hu
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
