[mapguide-internals] Area stylization
Jason Birch jason at jasonbirch.com
Mon Dec 14 20:19:05 EST 2009
Sweet, this is all working the way I want now.
I did run into something that was probably just a limitation of my
understanding.  I thought in my testing setting ClippingControl to Inside
made it not draw the individual bushes where they intersected with a polygon
boundary. Later tests showed that this caused the symbols to be clipped to a
rough bounding box of the polygon instead.  I hate it when I see things that
don't exist and don't even have an excuse :)
I'm fine with this as it stands (with parts of the individual bushes getting
cut off at polygon edges), but if there's a way to prevent these from
drawing if they intersect with the polygon outline that would be useful to
know.
Jason
2009/12/14 Walt Welton-Lair
> Your guesses were pretty much right on.
> - Symbols are always defined in millimeters, for both device and mapping
> size context.  For mapping size context you typically have to set the scales
> in the symbol instance to something larger than 1 to make the symbol a
> reasonable size for the map.  E.g. if you're at a mapscale of 1000 then at a
> symbol instance scale of 1 a 1 mm wide symbol will be 0.001 mm on your
> screen :-).
> - Yes, the ampersand is for accessibility.  It's not a fixed rule though.
>  It's how we at Autodesk have done it.
> - For the polygon border you'll need an additional line symbol - one that
> defines a LineUsage.  You can then either combine both the line and area
> symbol into one CompoundSymbolDefinition, or they can remain separate
> symbols but then you need two symbol instances in your layer definition.
>  Having them be separate symbols is more flexible - you can use the same
> line symbols for polylines and polygon borders.  It's also a good idea to
> include UsageContext and GeometryContext elements in your SymbolInstances to
> ensure there's no ambiguity when using and applying the symbols.  See the
> section in RFC 29 (https://trac.osgeo.org/mapguide/wiki/MapGuideRfc29) for
> a good description of what these do.
> Walt
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:
> mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
> Sent: Monday, December 14, 2009 6:09 PM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] Area stylization
> Cool, thanks!
> Setting the ClippingControl to Inside gave me exactly what I wanted for the
> interior fill.
> Few questions:
> - I just get black blobs when I try to set SizeContext to MappingUnits set
> in the LayerDefinition.  Is this unsupported, or do I just have to scale
> the
> symbol smaller or something?
> - Is the ampersand at the beginning of the DisplayName for accessibility
> (keyboard shortcut) in GUI clients or something?
> - I'm at a bit of a loss how to symbolize the polygon border.  Do I create
> this as a composite symbol with a separate symbol and LineUsage?
> I hate that I feel so clueless when working with this, thanks again for the
> help.
> Jason
> 2009/12/14 Walt Welton-Lair <walt.welton-lair at autodesk.com>
> > Area style support was initially available in MGOS 2.0.0, while a preview
> > of line style support was available in 1.2.0.  But it wasn't until 2.0.1
> > until both were reasonably stable.  I've updated RFC 14 to indicate this.
> > Here's a simple swamp symbol I hacked together:
> > <?xml version="1.0" encoding="UTF-8"?>
> > <SimpleSymbolDefinition xmlns:xsi="
> > http://www.w3.org/2001/XMLSchema-instance"
> > xsi:noNamespaceSchemaLocation="SymbolDefinition-1.1.0.xsd"
> version="1.1.0">
> >  <Name>SWAMP</Name>
> >  <Graphics>
> >  <Path>
> >   <Geometry>M -1.0,0.0 h 2.0 M -1.3,0.3 h 2.6 M 0.0,0.3 v 1.5 M -0.2,0.3
> l
> > -1.0,1.0 M 0.2,0.3 l 1.0,1.0</Geometry>
> >   <LineColor>%HATCHCOLOR%</LineColor>
> >  </Path>
> >  <Path>
> >   <Geometry>M 3.0,2.5 h 2.0 M 2.7,2.8 h 2.6 M 4.0,2.8 v 1.5 M 3.8,2.8 l
> > -1.0,1.0 M 4.2,2.8 l 1.0,1.0</Geometry>
> >  </Path>
> >  </Graphics>
> >  <AreaUsage>
> >  <Angle>0.0</Angle>
> >  <RepeatX>8.0</RepeatX>
> >  <RepeatY>5.0</RepeatY>
> >  </AreaUsage>
> >  <ParameterDefinition>
> >  <Parameter>
> >   <Identifier>HATCHCOLOR</Identifier>
> >   <DefaultValue>0xff000000</DefaultValue>
> >   <DisplayName>&amp;Hatch Color</DisplayName>
> >   <Description>Color for the hatch style</Description>
> >   <DataType>FillColor</DataType>
> >  </Parameter>
> >  </ParameterDefinition>
> > </SimpleSymbolDefinition>
> > Walt
> > Sent: Monday, December 14, 2009 3:06 PM
> > Subject: [mapguide-internals] Area stylization
> > I'm not clear on whether there is any area stylization support in the new
> > advanced stuff or not.  The schema has an AreaUsage section, but the RFCs
> > show that support would be deferred.
> > I'm trying to create a classic "Wetlands" area fill which has a stylized
> > bush ( *\|/* )  at an even/odd offset (or random) grid pattern fixed to
> > mapping units.  If anyone has any pointers on this, or even a "can't do
> > that, just use the stock Swamp symbol" I'd appreciate it. :)
> > Thanks,
> > Jason
> > mapguide-internals mailing list
> > mapguide-internals at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
