[mapguide-internals] Additional RFC60 review
Walt Welton-Lair
walt.welton-lair at autodesk.com
Tue Dec 22 00:48:38 EST 2009
Hi UV,
I've spent most of today reviewing your RFC60 changes. I agree with Trevor's
review comments, and I saw that you have already addressed most of them.
A note regarding tab characters, I plan to eventually rerun my utility
which cleans these up. I could wait to run it until after you have
merged and then it will fix your changes as well. That way you don't
have to do it this time. For future submissions though, please make
sure your code editor is configured to insert spaces and not tabs.
Here are my comments. There are a lot of them, but they're all fairly
straightforward to address. These assume your latest RFC 60 code.
Oem
- I assume nothing in this folder will be merged.
BuildTools\cc.net\ccnet.config
- Should not be merged.
Common\MapGuideCommon\MapLayer\Map.h
- You mentioned m_colorPalette is a lazy instantiated container. But both
MgMap constructors currently allocate a container rather than initialize
the pointer to NULL, so it's not lazy at all.
Common\MapGuideCommon\MapLayer\Map.cpp
- There are some memory leaks:
* MgMap::Create(MgResourceService* ...) has a leak. If the color
palette exists but is empty, a new one is allocated and the pointer is
overwritten without deleting the old object (if it exists).
* MgMap::Create(CREFSTRING ...) creates a memory leak. The constructor
allocates m_colorPalette, and this method clears the pointer without
first deleting the existing object.
* Inadvertent errors like this is a good reason to make m_colorPalette
be a ColorStringList, like Trevor originally suggested. I recommend
changing it as well. It simplifies the code and removes any chance of
a leak. The lazy instantiation performance improvement is not worth it
IMO.
- Me just nitpicking: don't add extra unnecessary newlines (line 411, 451)
- No need to clear the palette in MgMap::Dispose, since destructor will do it.
- In AddColorsToPalette you filter empty strings before calling std::transform,
but still add the empty strings to the color palette. Should they not be
added?
- You have calls to std::sort and std::unique in GetColorPalette. You
should therefore remove the sort/unique calls in ParseColorStrings in the
rendering service, since it calls GetColorPalette.
- Me just nitpicking: line 1144 - put the comment on a separate line.
Common\MapGuideCommon\Services\RenderingOptions.cpp
- Looks good.
Common\Renderers\AGGImageIO.cpp
- Includes should never be added before the include of "stdafx.h". When
precompiled header usage is enabled, any includes before stdafx.h are
ignored.
- Is the include of ace/OS.h needed when _DEBUG_PNG8 is turned on? If so
then wrap the include in an ifdef.
- Add back include of AGGRenderer.h (see notes for AGGImageIO.h).
- Remove commented include of smartalloc.h.
- Add a brief comment explaining the purpose of the UseColorMap static.
- In CreateGdImageWithPalette, declare gdPPaletteFromImg24 in the block
where it's actually used.
- In CreateGdImageWithPalette, get rid of commented calls to delete. They
distracting, as well as incorrect.
- The use of your myassert macro can lead to memory leaks.
* In CreateGdImageWithPalette, the third call to myassert can cause a leak.
Since the myassert macro throws an exception, the previously allocated
gdPPalette pointer ends up getting leaked. Same problem with the fourth
call to myassert in this method.
* There are two calls to myassert in one of the AGGImageIO::Save overloads.
Both result in leaks if the assert goes off. For the first, the gdImage24
pointer gets leaked, while for the second, the gdImage24 and gdImgPalette
pointers get leaked.
* Do you really want myassert to raise an exception?
- Lines 1011-1014: get rid of commented "former GIF code"
- Me just nitpicking: lines 962, 1015 - put comments on separate lines.
- Always keep at least one blank line between methods (preferably two).
Common\Renderers\AGGImageIO.h
- Remove the include of AGGRenderer.h (it's no longer needed now that you've
moved the RS_ColorVector definition to RenderStyles.h).
- We also want to avoid including gd.h in AGG class headers. The use of GD
within AGG is an implementation detail which shouldn't be exposed through
the headers. To make your code work without gd.h in the header, you can
either change the gdImagePtr parameters to void* (see for example GDRenderer's
m_imgout and m_imsym which also do this), or just change the new static
methods to be helper methods declared directly in AGGImageIO.cpp (works
since they're not referenced outside of AGGImageIO.cpp). I prefer the
latter.
Common\Renderers\AGGRenderer.cpp
- Separators missing before SupportsTooltips, ApplyLineStyles, ProcessArea,
DrawScreenPolyline, AddExclusionRegion
- Use slashes for method separators.
Common\Renderers\AGGRenderer.h
- Looks good.
Common\Stylization\DefaultStylizer.cpp
- Me just nitpicking: always keep at least one blank line between methods
(preferably two). E.g. StylizeGridLayer doesn't have any in your version
of the code.
Common\Stylization\DefaultStylizer.h
- For GetSymbolManager move the implementation to the cpp file. I realize
it's just a one-line implementation, but for consistency I always put
implementations in cpp files so people always know where to look. And use
newlines in the implementation. I remember some older versions of Visual
Studio would not let you hit breakpoints set on methods that were declared /
implemented on a single line.
Common\Stylization\RendererStyles.h
- Get rid of the gdImage and gdImagePtr typedefs. These are only used within
the Renderers project, and in there the typedefs are already available via
GD.
Server\Src\Common\Manager\Makefile.am
- See comments ServerRenderingService.h. If you remove the AGGRenderer.h
include from ServerRenderingService.h then no changes are needed to this
file.
Server\Src\Common\Manager\ServerManager.vcproj
- If you remove the AGGRenderer.h include from ServerRenderingService.h
then no changes are needed to this file.
- General note: when making changes to project file configuration settings
don't forget to update ALL configurations. You only made changes to the
Win32 configurations and didn't update the x64 configs.
Server\Src\PostBuild\PostBuild.mak
- This won't be merged, as mentioned in your response to Trevor's review
comments.
Server\Src\Services\Mapping\MappingUtil.cpp
- Was there a good reason to reorder all the includes? Linux builds are
sensitive to the include order (much more than Windows).
- The myassert define is not used in this file, so remove it.
- Comment on line 559: an FdoPtr isn't an autoPtr
- Lines 572-580: move the printf calls inside the if (extractColors) block.
- Lines 843-844: remove commented code
- Line 1335: remove commented code "bool isRef = false;"
- Comment line 1369: "the property setter canonicalizes the palette". Not
anymore with your latest changes.
- In ExtractColors, no need to check for an empty ColorStringList since
AddColorsToPalette already does.
- Calls to Rule::GetLabel - the returned label can be NULL and the code needs
to check for this.
- Calls to xxRule::GetSymbolization 0 the returned object can be NULL and the
code should check for this.
- When adding colors to the ColorStringList you're calling substr(), I think
to create a copy of the string since the MdfStrings returned from the API
are references. But isn't a copy automatically made when the string is added
to the list? Have you stepped into the std::list::push_back call to verify
that substr is actually needed?
- FindColorInSymDefHelper methods: is there honestly any benefit in declaring
these as inline?
- In GraphicElementVisitorImpl, add TODO comments for VisitImage and VisitText.
These can be implemented by someone at a later time.
- In the CompoundSymbol version of FindColorInSymDefHelper add a TODO comment
for the case where the symbol is defined via a resourceID reference. This can be
implemented at a later time.
- Curly braces go on new lines, per our coding style.
Server\Src\Services\Mapping\MappingUtil.h
- Looks good.
Server\Src\Services\Mapping\ServerMappingService.vcproj
- Does this file actually need to be changed?
- If so, only the Debug|Win32 configuration is currently updated, and all four
configurations need to be updated. Also, the Makefile.am file would need
to be updated.
Server\Src\Services\Rendering\ServerRenderingService.cpp
- Use newlines for implementation of hasColorMap().
- In your latest change you uncommented the new calls to MG_TRY / MG_CATCH
(I don't think Trevor realize you had originally added them as commented
code). The only renderer which actually does cleanup in EndMap is
DWFRenderer, so it could benefit from this change. The calls are not needed
though to skip faulty tiles (as mentioned in your code comment). If an
exception is raised in RenderMapInternal while generating a tile it will be
caught in RenderTile, and your RFC60 code will not be executed. Two
additional changes you need to make:
* You should use the MG_THROW macro and not re-throw the exception yourself.
Your code also has a reference count bug (look at MG_THROW).
* In the current code the exception is re-thrown only for debug. It must
always be re-thrown, and a server error will be logged further up in
the call stack.
- Issues with the RS_ColorVector:
* The tileColorPalette pointer is not initialized to NULL. In the case
of an exception occurring during the Save call while using GD, the code
(as it's currently written) will try to delete an uninitialized
pointer. While this code path should not currently happen, it may in
the future.
* There's a big memory leak: in the case of AGG the RS_ColorVector object
is allocated, but it's only getting deleted in the exception handler.
* Please clean all of this up by allocating the RS_ColorVector object
on the stack in the case of AGG. This is faster and it simplifies the
code.
- Line 955 which checks for the AGG renderer also now includes a check for
hasColorMap. This logic is wrong. If the renderer is AGG but hasColorMap
returns false then your code will jump to the else block and use GD
renderer.
- It looks like the RFC60 code in AGGImageIO raises std::exceptions, and
these are rethrown here. While the MG_CATCH macro will handle these,
does this provide sufficient information in the error log? Have you
checked this?
- The coding style of the "rfc60 code to correct colormaps" section needs
work:
* curly braces go on new lines
* code alignment is messed up (some lines aren't indented, others are
indented 3 characters)
* tab characters need to be replaced with spaces
- You added code to throw a MgNullArgumentException in the case where the
renderer did not return data. This type of exception is used when
"a null argument is passed to a method that expects a non-null value".
A better one might be MgStylizeLayerFailedException. In any case, why
do we need to throw the exception? Is it to log an error? Is this a
requirement of RFC60, or is it to address some other issue? Also,
put the throw call on a new line so it's easy to set a breakpoint on
that specific line.
Server\Src\Services\Rendering\ServerRenderingService.h
- Now that you've moved the RS_ColorVector definition to RenderStyles.h,
you can get rid of the include of AGGRenderer.h. This lets you avoid having
to update the ServerManager project include paths.
- If you also move ParseColorStrings to StylizationUtil as Trevor suggested,
Server\Src\Services\Tile\ServerTileService.cpp
- You changed a reference to MgUnableToOpenTileFile to MgUnableToOpenLockFile.
Looking at where MgUnableToOpenTileFile is used, it does seem to always
refer to an error opening the lock file. So this change seems ok, but:
* also update the other two places where it's used
* you must also update the resource file
- file is at Common\MapGuideCommon\Resources\mapguide_en.res
- update the name of the resource
- update content/value: "Unable to open the tile lock file." sounds
reasonable
* get rid of the "MgUnableToOpenTileFile???? sounds wrong" comment
- Get rid of "refactored from below" comment and remove the commented code.
Your code improvement is good.
Server\Src\Services\Tile\ServerTileService.h
- I agree with Trevor's comments for this file. The GetResourceServiceForMapDef
method would definitely be worthwhile if it was called from at least two
places. But it's only used in one place and it's relatively small method,
so IMO there's no tangible benefit.
Server\ServerStructured.sln
W E @__ __o
A T R @___ _ \<,_
L @_ (*)/ (*)
More information about the mapguide-internals
