[mapguide-internals] RFC 49 parameter logging delimiters tweak
Zac Spitzer zac.spitzer at gmail.com
Mon Feb 2 17:36:53 EST 2009
The server start stop logging is also worth mentioning :)
http://trac.osgeo.org/mapguide/changeset/3578
z
On Tue, Feb 3, 2009 at 9:24 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> sweet!
> On Tue, Feb 3, 2009 at 6:59 AM, Bruce Dechant
> <bruce.dechant at autodesk.com> wrote:
>> Zac,
>> I just submitted a fix for this as the logging enhancements for RFC49 should be using the serverconfig.ini setting LogsDelimiter for the delimiter character and not a hard coded comma character.
>> Thanks,
>> Bruce
>> -----Original Message-----
>> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
>> Sent: Friday, December 26, 2008 10:54 PM
>> To: MapGuide Internals Mail List
>> Subject: [mapguide-internals] RFC 49 parameter logging delimiters tweak
>> Currently the delimiters for the parameters use a comma as the
>> delimiter between the options,
>> it makes parsing the parameters harder than neccesary as there are
>> often commas in the WKT
>> Resource=Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource,ClassName=SDF_2_Schema:VotingDistricts,Options={{Operator=1}{GeomProp=Data}{GeomOp=10}{Geometry=POLYGON
>> ((-87.783866628374042 43.691398128787803, -87.676641873488435
>> 43.691398128787803, -87.676641873488435 43.797520000480297,
>> -87.783866628374042 43.797520000480297, -87.783866628374042
>> 43.691398128787803))}}
>> Would it make sense to use a semi-colon instead, just to make parsing
>> this easier?
>> I am writing a up little php script which parses the Trace.log and
>> re-executes the
>> query for performance profiling
>> Enhancing the END entries by adding the BGN parameters and elapsed time, maybe
>> as level 4 would make the log files useful without pre-processing
>> z
>> Zac Spitzer -
>> http://zacster.blogspot.com
>> +61 405 847 168
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer -
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
More information about the mapguide-internals mailing list
