[mapguide-internals] About the WiX installer
Jason Birch Jason.Birch at nanaimo.ca
Mon Feb 16 23:51:23 EST 2009
Hey Jackie,
There are some path variables in the project properties that you will have to point to the correct locations...  I think that should be it.
Note; I may have used a static fdo pointing to a pre beta 3.4 release, and geos was made dynamic so that dll will need to be added to the files.
Jason
----- Original Message -----
From: mapguide-internals-bounces at lists.osgeo.org <mapguide-internals-bounces at lists.osgeo.org>
To: mapguide-internals at lists.osgeo.org <mapguide-internals at lists.osgeo.org>
Sent: Mon Feb 16 20:38:23 2009
Subject: [mapguide-internals] About the WiX installer
Hi All,
I'm trying to grok the WiX installer files. When trying to build the wix
installers, it is erroring out because it can't find a whole load of files.
Given a checkout of the mapguide svn trunk, what do I need to do to ensure
the wix installers build without problems?
- Jackie
View this message in context: http://n2.nabble.com/About-the-WiX-installer-tp2339047p2339047.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
