[mapguide-internals] About the WiX installer
Jason Birch Jason.Birch at nanaimo.ca
Tue Feb 17 04:02:39 EST 2009
Looks like there is a version of Paraffin that works with 3.0 now:
http://tinyurl.com/cd43qz <http://tinyurl.com/cd43qz>
So re-generating the files listings and setting up file includes that can be kept up to date with Paraffin is probably a great idea anyway.  Note: I believe that some files (providers.xml, serverconfig.ini, etc) will need to be removed from the autogenerated file listings and managed separately so they can be referenced consistently in custom actions.
I had actually explored using heat to generate some of these file lists because of my frustration editing Paraffin files, but Parrafin 3 tilts the field back in its favour.  heat is still useful for harvesting IIS website settings.
Jason
Sent: Mon 2009-02-16 11:55 PM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] About the WiX installer
I had to re-run some of the Parafin scripts to match the actual files on
my machine.
More information about the mapguide-internals mailing list
