[mapguide-internals] About the WiX installer
Jason Birch Jason.Birch at nanaimo.ca
Thu Feb 19 12:43:54 EST 2009
This environment variable is set in
https://trac.osgeo.org/mapguide/browser/trunk/Installer/Libraries/CS%20M
ap/CSMap.wxs
Based on the location (directory ID) of the CSMap dictionary files that
is hard-coded in the include files:
http://tinyurl.com/bl6tho
I'm guessing that this got walked on when you refreshed the file list.
I couldn't find a way of abstracting the files in a way that would be
safe from these updates.  The whole installer process appears to be
based on manually maintaining the file list once it is initially
generated.  They have a couple tools (auto-GUID generation based on
keypath, etc) that make this easier, but setting usable directory
identifiers and other similar things is problematic.
Jason
-----Original Message-----
Sent: February-19-09 6:12 AM
To: mapguide-internals at lists.osgeo.org
Subject: RE: [mapguide-internals] About the WiX installer
For some reason the installer doesn't seem to want to set the
MENTOR_DICTIONARY_PATH environment variable during installation. Any
possible reason?
I'm using Windows XP Pro SP3.
More information about the mapguide-internals mailing list
