[mapguide-internals] About the WiX installer
Jason Birch Jason.Birch at nanaimo.ca
Tue Feb 24 03:12:22 EST 2009
Yes, that was the rationale.
MapGuide still has far more potential new users at each release than existing users, and we have to make the install story easy enough that they are tempted to try it out.  This is also why I want the full FDO release binaries in the install, even if the ones with external dependencies (rdbms providers mostly) are initially commented out.
Ideally, we'd have a Quick Start feature, including the sample data and developer code as well as an intro html page (like that which comes with tomcat) with links to the admin page, web API pages, demo maps, strategic web resources, etc...
I did try to structure the code in a way that would allow feature-specific install wrappers to be created easily while sharing the same setup code; so if there is a strong demand for this I don't think it would be hard to do after the initial release.
I hope later this year to look at integrating with OSGeo4W as well, but my experience trying to get mapguide to compile against newer apache/php has me a bit scared :)
Jason
----- Original Message -----
From: mapguide-internals-bounces at lists.osgeo.org <mapguide-internals-bounces at lists.osgeo.org>
To: MapGuide Internals Mail List <mapguide-internals at lists.osgeo.org>
Sent: Mon Feb 23 23:28:05 2009
Subject: Re: [mapguide-internals] About the WiX installer
I think Jason made that decision, so he can probably answer better.
I prefer to keep it as a single installer, because you need both anyway,
so this way there is only one download.
Most users do not have multiple machines, and just want to install
everything and try it out.
Experienced users, can just de-select the parts they dislike, and
install the desired components on seperate machines.
Regards, Kenneth Skovhede, GEOGRAF A/S
Jackie Ng skrev:
> Okay another question.
> What is (was) the reasoning behind having a combined installer, as opposed
> to separate web / server tier installers?
> - Jackie
> Jackie Ng wrote:
>> Hi All,
>> I'm trying to grok the WiX installer files. When trying to build the wix
>> installers, it is erroring out because it can't find a whole load of
>> files.
>> Given a checkout of the mapguide svn trunk, what do I need to do to ensure
>> the wix installers build without problems?
>> - Jackie
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
