[mapguide-internals] VOTE: Add Jackie Ng as a committer (Re: OSGeo Project Contributor agreements)
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Feb 26 03:24:05 EST 2009
Does that mean that you never recieved mine?
Regards, Kenneth Skovhede, GEOGRAF A/S
Tyler Mitchell (OSGeo) skrev:
> Hi Jackie,
> I see I didn't add your name to the MapGuide list on the wiki page.  I
> guess yours is the first MGOS one I received, I had to start a new
> table for it.  Does that make sense?
> You should be good to go!
> Tyler
> On 24-Feb-09, at 4:08 PM, Jackie Ng wrote:
>> I submitted two contributor agreements months ago (one for FDO and
>> one for MGOS). I never knew if the MGOS one got accepted.
>> 2008/10/15 Tyler Mitchell (OSGeo) <tmitchell at osgeo.org>
>> Good to know!  Works for me, thank you.
>> Bob - can we get MGOS onto the CLA somewhere?
>> Begin forwarded message:
>> From: "Jackie Ng" <jumpinjackie at gmail.com>
>> Date: October 14, 2008 12:46:47 PM PDT (CA)
>> To: "Tyler Mitchell (OSGeo)" <tmitchell at osgeo.org>
>> Subject: Re: OSGeo Project Contributor agreements
>> Hi Tyler,
>> The MGOS one does not mention the actual project name. Hence I wrote
>> it on the back of the document.
>> See for yourself:
>> http://mapguide.osgeo.org/files/Individual%20Contributor%20Agreement.pdf
>> - Jackie
>> Hi Jackie,
>> Sorry for a slow response, I've been on vacation.  I received your
>> documents, thank you.  Did you keep a copy of them?  The reason I ask
>> is that the FDO one is fine, but the other one did not mention what
>> project it was for.  I will need you to resend that one.  I notice
>> you say it is for MGOS - was that mentioned anywhere in the
>> document?  I might just have a bad eyes.
>> I keep track of all contributor agreements here:
>> http://wiki.osgeo.org/wiki/Contributor_Agreements_Received
>> Hope that helps.  I was going to follow up with anyway, so thank you
>> for being in touch.  I'm your primary contact on this topic.
>> Tyler
>> On 6-Oct-08, at 2:23 AM, Jackie Ng wrote:
>> Hi All,
>> I recently (a week and a bit ago) mailed two signed Project
>> Contributor agreement documents (one for MapGuide Open Source and one
>> for Feature Data Objects), my questions are:
>> 1) What is the usual turnaround time for Project Contributor
>> agreements be processed?
>> 2) How will I know if my mailed agreements have been accepted?
>> Regards,
>> - Jackie
>> Blog: http://themapguyde.blogspot.com
>> LinkedIn: http://www.linkedin.com/in/jackieng
>> Twitter: http://twitter.com/jumpinjackie
>> "A SQL query walks into a bar and sees two tables. He walks up to
>> them and says 'Can I join you?'"
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
