[mapguide-internals] API-less map display via AJAX
Zac Spitzer
zac.spitzer at gmail.com
Mon Jul 6 03:19:27 EDT 2009
> The GETMAPCONFIG can be substituted by the GETRESOURCECONTENT
> call on the MapDefinition, which would return all the required information.
only the scales are stored in the map xml, it's the calculated extent
and the dpi which are missing, plus the map def can be rather large
z
> However, I am unsure how well this works if authoring is disabled on the web
> tier.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Zac Spitzer skrev:
>> I'm thinking bout writing a RFC for operation=GETMAPCONFIG which would
>> return
>> the bounds, scales and DPI for a given map and operation=LOADMAP to allow
>> a runtime map to be created without API work.
>> This is direly needed for use with openlayers so that we can autoconfigure
>> for using mapguide maps purely with HTTP calls and no api.
>> z
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
