[mapguide-internals] Re: Please review RFC 74
Christine Bao
Christine.Bao at autodesk.com
Tue Jul 7 22:41:58 EDT 2009
Hi Kenneth,
Thank you for your reply. Here are my comments:
1. EnumerateReferences call is slow.
This RFC is to improve performance by reducing network communication and the code is executed in server side. I didn't have plan to change EnumerateReferences() call before read your comments. Now I check the function, and find it's by XmlDb query. Well it's the most efficient way to me. Do you have suggestion how to make it faster?
2. Re-pointed
When copying resource I'll not change the referencing content. In your case the result is a little different. "FolderB/Layer -> FolderA/FeatureSource2" instead of "FolderB/Layer -> FolderB/FeatureSource2". This RFC's goal is to keep link when moving/renaming resource, and because copying resource will not break the link I'll not make change. Your ticket about "Repointer" is a good suggestion, but it's different from this RFC, so it's not covered here.
Thanks & regards,
Christine
From: "Kenneth Skovhede, GEOGRAF A/S" <ks at geograf.dk>
Subject: Re: [mapguide-internals] Please review RFC 74
To: MapGuide Internals Mail List <mapguide-internals at lists.osgeo.org>
Message-ID: <4A5329BA.8050102 at geograf.dk>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Nice, this will make the operation much faster.
Using Maestro, I can see that the EnumerateReferences call is the real
speed killer.
If implemented in the server code, I expect the actual XmlDb call to be
just as slow.
Are there any efforts to investigate this, or is it just "as good as it
gets"?
Maestro also has a similar function when copying a folder,
all resources within the folder gets "re-pointed" to related copies.
Eg.:
Structure before copy:
FeatureSource1
FolderA/Layer -> FeatureSource1
FolderA/Layer -> FolderA/FeatureSource2
After copy of FolderA to new name FolderB:
FeatureSource1
FolderB/Layer -> FeatureSource1
So the relationship within the folder is kept.
Would this be a candidate for implementation with the RFC as well?
Jason has requested a generic "re-pointer" function for Maestro, that I
have yet to implement:
http://trac.osgeo.org/mapguide/ticket/606
Would you consider adding that as part of the RFC?
Regards, Kenneth Skovhede, GEOGRAF A/S
More information about the mapguide-internals
