[mapguide-internals] Re: Please review RFC 73
Christine Bao Christine.Bao at autodesk.com
Tue Jul 7 23:27:31 EDT 2009
Hi Kenneth,
     Thank you for your comments.
1.  The load that would be removed would be for sequential requests to the XmlDb?
I'm not sure about your meaning. If you're talking about how to get the collection of resource contents by the collection of resource ids, I'm going to leverage the existing GetResourceContent(resourceid, preprocesstag) function. Yes, it will call XmlDb by a sequential requests.
2.       How much improved?
It's hard to give a number. The more layers in a map, the more significantly improved. We'll have performance test later to see how it improves.
3.       Expose to WebTier
Yes, then it should be PUBLISHED_API instead of INTERNAL_API, is it right?
Thanks & regards,
Christine
From: "Kenneth Skovhede, GEOGRAF A/S" <ks at geograf.dk>
Subject: Re: [mapguide-internals] Please review RFC 73
To: MapGuide Internals Mail List <mapguide-internals at lists.osgeo.org>
Message-ID: <4A53272C.8020502 at geograf.dk>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
XmlDb?
This is definately a logic improvement, but have you quantified how much
faster this will make the MgMap operation?
Would you consider exposing this improved function to the WebTier?
Regards, Kenneth Skovhede, GEOGRAF A/S
More information about the mapguide-internals mailing list
