[mapguide-internals] test data / maps for new stylization needed
    Walt Welton-Lair
    walt.welton-lair at autodesk.com
    Tue Jul 14 01:09:27 EDT 2009
Sorry UV, I don't have any enhanced stylization packages with tiled maps handy.
But you could temporarily modify the unit test data to quickly get something useful, i.e. change the layers referenced in the RenderingService MapDefinitions (MDFs) to be tiled layers (BaseMapLayer elements) instead of regular layers.  You can use the TileService unit test MDF (UT_BaseMap.mdf) as a guide (these unit test files simply contain XML data).  You may also need to update the set of FiniteDisplayScales in the MDF to something more appropriate.  Finally, just replace the RenderMap calls in TestRenderingService with RenderTile (with appropriate row / column values).
The nice thing about this approach is that once it's set up you can very easily tweak the settings, especially the symbol definitions.
If you do take this approach then I'd recommend going a little further and coding it up as a new / separate rendering service unit test.  The test would specifically exercise your new functionality, and you could then include it as part of your RFC 60 submission.  Just create copies of the data files you need to tweak and have the new test reference these.
Walt
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of UV
Sent: Saturday, July 11, 2009 4:34 AM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] test data / maps for new stylization needed
In order to move forward in implementing code for new stylization some
test data would be useful.
The data in the rendering service unit tests does not use tiles so its
of no use for RFC60.
Anyone has a package that can be used for such purpose please?
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
