[mapguide-internals] Web Layout XML Schema Update (Re: RFC 66)
Jason Birch
Jason.Birch at nanaimo.ca
Fri Jul 17 11:54:50 EDT 2009
Nope, map image format is specifiable in the Map's Extension section as ImageFormat, and has been since at least 1.1. That was the one I was more sure of because I use it.
<Map xsi:type="MapGuideLayerType">
<Type>MapGuide</Type>
<SingleTile>true</SingleTile>
<Extension>
<ResourceId>Library://Nanaimo/Apps/NanaimoMap/Maps/Themes/Default.MapDefinition</ResourceId>
<ImageFormat>PNG8</ImageFormat>
Jason
-----Original Message-----
Sent: Friday, July 17, 2009 8:42 AM
To: mapguide-internals at lists.osgeo.org
Subject: Re: [mapguide-internals] Web Layout XML Schema Update (Re: RFC 66)
I know selection color is definitely supported in the app definition, map
image format requires a hacking of openlayers.js to my knowledge.
More information about the mapguide-internals
