[mapguide-internals] Measure tool should not use
GetResourceContent to check if resource exists
Jackie Ng
jumpinjackie at gmail.com
Wed Jul 22 12:32:34 EDT 2009
That would be here:
MgDev/Doc/samples/phpsamples/digitizing_features/draw_line.php
- Jackie
Bruno Scott wrote:
> Thanks for the java patch Jackie
> I made a global search, and i only found one other
> devguide/digitizing_features/draw_line.php
> But i don't know where the sources are
> Bruno
> Jackie Ng wrote:
>> Poor java, does get any love. So I've put in a equivalent patch for the
>> java viewer :-)
>> Other than that, looks fine. Could there possibly be more areas in the
>> map viewer code where GetResourceContent() is (mis)used in this fashion?
>> - Jackie
>> Bruno Scott wrote:
>>> Please review this patch
>>> http://trac.osgeo.org/mapguide/ticket/1045
>>> Bruno Scott
View this message in context: http://n2.nabble.com/Measure-tool-should-not-use-GetResourceContent-to-check-if-resource-exists-tp3303377p3304374.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
