[mapguide-internals] Maestro and compatibility with previous mapguide versions.
Zac Spitzer zac.spitzer at gmail.com
Thu Jul 23 08:22:50 EDT 2009
it would be good to have some sort of register of users by version n api...
On Thu, Jul 23, 2009 at 9:41 PM, Jackie Ng<jumpinjackie at gmail.com> wrote:
> The flipside to that is that the need to support 1.2 may hinder certain
> enhancements from being implemented. Which is why I raised the original
> question.
> - Jackie
> Gabriele Monfardini wrote:
>>> Generally I would like Maestro to be compatible with all versions of
>>> MapGuide.
>> Great.
>>> But versions older than 1.2 are not supported, and once 2.1 comes out,
>>> I think 1.2 support could be deprecated.
>>> And by deprecated I mean, just not accept tickets fixing issues with that
>>> version.
>> Please continue supporting version 1.2 if it's possible (and not too much
>> work).
>> Some people is still using 1.2 due to some problem with 2.x (eg.
>> horrible compilation problem under GNU/Linux or problems with new
>> Postgis provider).
>> And Maestro is a great tool to work with.
>>> So far, MapGuide has not broken any backwards compatibility, so
>>> when implementing a new feature everything else should work fine anyway.
>>> I only have access to a few versions of MapGuide, so I generally only
>>> test
>>> with the most recent release (2.1 atm).
>> Well, obviously this is fine.
>> Until now 2.x API is largely the same as 1.2 so no problems at all.
>> Thank you for your work
>> Gabriele
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> View this message in context: http://n2.nabble.com/Maestro-and-compatibility-with-previous-mapguide-versions.-tp3307965p3309041.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals mailing list
