[mapguide-internals] MapGuide RFC 65 - ACE 5.6 upgrade is ready for review
Traian Stanev traian.stanev at autodesk.com
Thu Jun 4 19:28:01 EDT 2009
It is possible to run without the lock (and also without a similar lock that exists on the other side of the GDAL provider), provided that a fix is made to the GDAL provider refcounting. This was held back for the 2.1 release due to concerns by Haris and Jason (and others) about removing the lock being risky. There was a long thread about this a month or so ago.
Traian
________________________________________
From: mapguide-internals-bounces at lists.osgeo.org [mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
Sent: Thursday, June 04, 2009 4:49 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] MapGuide RFC 65 - ACE 5.6 upgrade is ready    for     review
Good catch Jason.  The ACE_GUARD will make all raster processing single threaded.  I believe Gdal and WMS would fall into this category.  Serverconfig.ini settings can also affect the number of concurrent connections.
Thanks,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Thursday, June 04, 2009 2:45 PM
Looks like one of the locks is still there:
http://trac.osgeo.org/mapguide/browser/branches/2.1/MgDev/Server/src/Services/Mapping/MappingUtil.cpp#L675
Was there something else in there limiting the raster provider to a single connection?
Jason
Sent: Thursday, June 04, 2009 1:35 PM
Big giant locks would certainly affect multi-core scalability.  I know Bruce did a whole ton of work on the Fdo connection management in MapGuide to improve Gdal threading issues.  I don't know if the big giant lock went it.
Sent: Thursday, June 04, 2009 2:15 PM
While this is true, don't we also have the big giant lock in the code, which makes sure that if you have rasters for example (where I/O matters), you will only be working on one request at a time anyway?
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
