[mapguide-internals] my 2.1 testing results
Zac Spitzer
zac.spitzer at gmail.com
Mon Jun 15 10:18:41 EDT 2009
there were some issues with mapguide overloading the system, ie use more
ram beyond what was available and started to page heavily whilst at 100% cpu
but it all worked out ok, just that the system was rendered (sic!)
unuseable whilst tiling at some of the higher scales ie in the millions
Uv hit the same stuff and hence wrote up
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc63
being able to restrict the tile service to x threads would help
I do have my firefox set to 8 concurrent connections, whilst using my
javascript tiler
z
On Tue, Jun 16, 2009 at 12:00 AM, Zac Spitzer<zac.spitzer at gmail.com> wrote:
> On Mon, Jun 15, 2009 at 7:33 PM, Trevor
> Wekel<trevor_wekel at otxsystems.com> wrote:
>> Hi Zac,
>> A couple of quick questions on your testing:
>> What API variant were you using (PHP, .Net, Java)?
> just openlayers :) was just heavy tiling
>> Was your testing multi-user/multi-threaded?
>> - If so, how many cores was the MapGuide server using?
> it's a desktop with 4 cores and 3gb of ram
>> Did you have connection pooling enabled for SDF and SHP?
> nope
> I'll send you my serverconfig off list
>> Thanks,
>> Trevor
>> -----Original Message-----
>> From: mapguide-internals-bounces at lists.osgeo.org
>> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
>> Sent: Sunday, June 14, 2009 11:39 PM
>> To: MapGuide Internals Mail List
>> Subject: [mapguide-internals] my 2.1 testing results
>> Hey All,
>> I did some serious testing of the 2.1 beta over the weekend with our
>> large Aussie map base and the results were fantastic. Super stable
>> and really good CPU utilisation, plus all the usual disk trashing I came
>> to expect no longer occurred.
>> Once the SDF/SHPs has been hit a few times, stuff was oft rendered
>> without the hd disk light barely lighting up!
>> two days of rendering and the mapguide process was only up to 128mb
>> and the error log was empty!
>> Great work team!
>> z
>> Zac Spitzer -
>> http://zacster.blogspot.com
>> +61 405 847 168
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer -
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
More information about the mapguide-internals
