[mapguide-internals] Re: Please review RFC 66
Zac Spitzer
zac.spitzer at gmail.com
Mon Jun 22 02:10:15 EDT 2009
how about GETSITEVERSION ? that's what I have used for keepalives in
my own stuff
and it returns a much smaller response?
z
On Mon, Jun 22, 2009 at 4:05 PM, Christine
Bao<Christine.Bao at autodesk.com> wrote:
> Hi Kenneth,
> Thank you for your suggestion. Here are my comments:
> 1. A real function to support "keep alive" pings
> We plan to call "GETFEATUREPROVIDERS" through MapAgent to keep alive. This function is light-weighted and won't cause much overhead. Using this method is the easiest way to approach it. Your suggestion makes sense, but we'll need to add another API which is only for this purpose, so we decide not to do this.
> 2. The client read out timeout value to adjust ping interval
> I'm afraid it's too much complicated. The plan is to ping server at a fixed time interval (of course you can set it in configuration), and the interval won't change during runtime. It works as Fusion does.
> 3. Connection broken
> Once the connection broken or timeout because server down, the client will stop ping server. But it will not recovery from a broken/timeout session.
> Thanks & regards,
> Christine
> Message: 3
> Date: Fri, 19 Jun 2009 12:41:14 +0200
> From: "Kenneth Skovhede, GEOGRAF A/S" <ks at geograf.dk>
> Subject: Re: [mapguide-internals] RE: Please review RFC 66
> To: MapGuide Internals Mail List <mapguide-internals at lists.osgeo.org>
> Message-ID: <4A3B6B4A.7050206 at geograf.dk>
> Content-Type: text/plain; charset=ISO-8859-3; format=flowed
> I commented on the issue as well.
> You are free to ignore it, but in case you somehow missed it, here it is:
> http://n2.nabble.com/Please-review-RFC-66-tc3090381.html#a3092233
> Regards, Kenneth Skovhede, GEOGRAF A/S
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
