[mapguide-internals] Re: Please review RFC 66
Christine Bao
Christine.Bao at autodesk.com
Tue Jun 23 02:53:42 EDT 2009
Hi Kenneth,
About your questions:
1) I'll use GETSITEVERSION instead of GETFEATUREPROVIDERS. You mentioned "if admin functions are disabled in the web tier". Would you please explain more about this?
2) The interval value should be set a reasonable value to make it work well. For example, the server timeout value is 20 minutes by default, and Fusion pings server every 5 minutes, so the ping can keep browser alive. Basic web layout will ping each 5 minutes also.
3) The third one is about when to stop pinging server. My solution so far is: if request fail (MgConnectionFailedException) the ping will stop. It's possible that the server is busy and returns this exception, and it will recovery after a while, but I still prefer to stop pinging because: a) The exception happening means server is busy, so browser should stop pinging to release overhead. b) Keep-alive is a nice to have function, the browser still works without pinging. c) Once user refresh the browser, pinging comes back.
Thanks & regards,
Christine
> On Mon, Jun 22, 2009 at 4:55 PM, Kenneth Skovhede, GEOGRAF
> A/S<ks at geograf.dk> wrote:
>> 1)
>> On my setup "GETFEATUREPROVIDERS" returns 13Kb worth of xml.
>> It may not consume CPU resources, but it does consume bandwidth,
>> especially since it is not required, and it happens a fixed intervals,
>> even if the user is inactive.
>> If its too much work to put in a real function, I think Zac's proposal is
>> way better,
>> but I'm not sure it will work if admin functions are disabled in the
>> WebTier.
>> 2)
>> There is a clear 1-1 relation between the server timeout setting and the
>> client ping setting.
>> If you can read the timeout value on viewer startup, that is fine, but I
>> don't think you can.
>> If you require the admin-user to change the time in two places, you can be
>> certain
>> that there will be a pile of support requests.
>> Also, for a non-specialist, it is not immediately obvious that the two
>> should not be the
>> same, eg. setting both to 15 minutes will make the sessions expire at
>> random, due to races
>> and clock drift.
>> 3) I have seen scenarios where a single reqest fails.
>> If you know the duration of the session, it is easy to ignore "connection
>> broken" responses,
>> and only stop pinging when there has been no positive response within a
>> session duration.
>> I think you need to adress issue 1 and 2.
>> Issue 3 is easy and will improve failure resilience, but not required.
>> Regards, Kenneth Skovhede, GEOGRAF A/S
More information about the mapguide-internals
