[mapguide-internals] Re: Please review RFC 66
Zac Spitzer
zac.spitzer at gmail.com
Tue Jun 23 09:23:46 EDT 2009
hmmm, i think that should be changed? thoughts?
GetSiteVersion is important
z
On Tue, Jun 23, 2009 at 7:02 PM, Kenneth Skovhede, GEOGRAF
A/S<ks at geograf.dk> wrote:
> 1)
> In the file "webconfig.ini" you can set:
> DisableAuthoring = 1
> Which will disable a lot of features in the MapGuide server.
> It is recommended to do so in the Autodesk MapGuide Security Whitepaper
> (page 3, middle).
> http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=7798553
> I just tested this, and the GetSiteVersion method is disabled,
> when DisableAuthoring is enabled.
> FYI, GetFeatureProviders is also disabled.
> This means that the keepalive feature will not work on a secure site.
> This leads back to my original comment: Make a seperate method for this.
> 2)
> How does the client (fusion, basic layout) read the timeout value?
> The "20" minutes is set in the serverconfig.ini, and many people may have
> changed that value.
> If the session timeout is changed to say 5 min, in order to handle heavy
> load better,
> the keepalive system will not work as expected.
> 3) Ok, MgConnectionFailedException is a good place to stop pinging. I was
> thinking more of a "no response" type error when I wrote it.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Christine Bao skrev:
>> Hi Kenneth,
>> About your questions:
>> 1) I'll use GETSITEVERSION instead of GETFEATUREPROVIDERS. You
>> mentioned "if admin functions are disabled in the web tier". Would you
>> please explain more about this?
>> 2) The interval value should be set a reasonable value to make it
>> work well. For example, the server timeout value is 20 minutes by default,
>> and Fusion pings server every 5 minutes, so the ping can keep browser alive.
>> Basic web layout will ping each 5 minutes also.
>> 3) The third one is about when to stop pinging server. My solution so
>> far is: if request fail (MgConnectionFailedException) the ping will stop.
>> It's possible that the server is busy and returns this exception, and it
>> will recovery after a while, but I still prefer to stop pinging because: a)
>> The exception happening means server is busy, so browser should stop pinging
>> to release overhead. b) Keep-alive is a nice to have function, the browser
>> still works without pinging. c) Once user refresh the browser, pinging comes
>> back.
>> Thanks & regards,
>> Christine
>>> On Mon, Jun 22, 2009 at 4:55 PM, Kenneth Skovhede, GEOGRAF
>>>> 1)
>>>> On my setup "GETFEATUREPROVIDERS" returns 13Kb worth of xml.
>>>> It may not consume CPU resources, but it does consume bandwidth,
>>>> especially since it is not required, and it happens a fixed intervals,
>>>> even if the user is inactive.
>>>> If its too much work to put in a real function, I think Zac's proposal
>>>> is
>>>> way better,
>>>> but I'm not sure it will work if admin functions are disabled in the
>>>> WebTier.
>>>> 2)
>>>> There is a clear 1-1 relation between the server timeout setting and the
>>>> client ping setting.
>>>> If you can read the timeout value on viewer startup, that is fine, but I
>>>> don't think you can.
>>>> If you require the admin-user to change the time in two places, you can
>>>> be
>>>> certain
>>>> that there will be a pile of support requests.
>>>> Also, for a non-specialist, it is not immediately obvious that the two
>>>> should not be the
>>>> same, eg. setting both to 15 minutes will make the sessions expire at
>>>> random, due to races
>>>> and clock drift.
>>>> 3) I have seen scenarios where a single reqest fails.
>>>> If you know the duration of the session, it is easy to ignore
>>>> "connection
>>>> broken" responses,
>>>> and only stop pinging when there has been no positive response within a
>>>> session duration.
>>>> I think you need to adress issue 1 and 2.
>>>> Issue 3 is easy and will improve failure resilience, but not required.
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
