[mapguide-internals] MapGuide RFC 69 - Rendering Layer Styles using Style Order
Zac Spitzer zac.spitzer at gmail.com
Thu Jun 25 22:36:54 EDT 2009
At the moment the only way to achieve this is to split the road network out into
multiple layers which is rather ugly.
Taking a road network as the example here, it's only at the
intersections where this
problem occurs.
Can some elaborate on how the server currently handles this?
z
On Fri, Jun 26, 2009 at 12:28 PM, Walt
Welton-Lair<walt.welton-lair at autodesk.com> wrote:
> "Proposed solution: Add support to the rendering engine to render layer styles in ordered passes."
> I'd like to see some concrete suggestions in the RFC on how to actually do this efficiently.  Just consider a conservative use case - say around 10  rules.
> Walt
> ________________________________________
> From: mapguide-internals-bounces at lists.osgeo.org [mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer [zac.spitzer at gmail.com]
> Sent: Thursday, June 25, 2009 9:29 PM
> To: MapGuide Internals Mail List
> Subject: [mapguide-internals] MapGuide RFC 69 - Rendering Layer Styles using    Style Order
> I have posted a new RFC
> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc69
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
+61 405 847 168
More information about the mapguide-internals mailing list
