[mapguide-internals] RE: Refactoring Web .NET API into Common DLLs
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Fri Jun 26 03:05:46 EDT 2009
Clever suggestion, single compile and multiple linking.
That should make it backwards compatible.
Could you update the RFC with this idea?
Regards, Kenneth Skovhede, GEOGRAF A/S
Leaf Li skrev:
> All,
> I think your major concerns is whether this change will break the existing MapGuide application after users update to new version of MapGuide.
> It can be resolved by one of the following solutions.
> 1. We still use SWIG to create MapGuideNotNetAPi.dll. It exists with refactoed dlls. Then no existing MG application will be broken.
> 2. Use .NET assembly with multiple file to resolve it.
> a) Create the following netmodule files
> i. OSGeo.MapGuide.Foundation.netmodule
> ii. OSGeo.MapGuide.Geometry.netmodule
> iii. OSGeo.MapGuide.PlatformBase.netmodule
> iv. OSGeo.MapGuide.MapGuideCommon.netmodule
> v. OSGeo.MapGuide.Web.netmodule
> b) Use al.exe to create an assembly for each .netmodule in step (a). Then the following files will be created.
> i. OSGeo.MapGuide.Foundation.dll
> ii. OSGeo.MapGuide.Geometry.dll
> iii. OSGeo.MapGuide.PlatformBase.dll
> iv. OSGeo.MapGuide.MapGuideCommon.dll
> v. OSGeo.MapGuide.Web.dll
> c) Use al.exe to create an assembly for all .netmodule in step (a). The following file will be created.
> i. MapGuideDotNetApi.dll
> By the solution, all assembly contains only a list of .netmodule. They are very small. Metadata and IL code are located in .netmodule.
> So it isn't a problem.
> Thanks,
> Leaf Li
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
