[mapguide-internals] Installer Automated build
Jackie Ng jumpinjackie at gmail.com
Thu Mar 5 19:48:52 EST 2009
Hi Kenneth,
MgDev\build.bat with no parameters does the build. You then need to run it
with the -a=install parameter which will copy all the files to a staging
area in MgDev\<Debug|Release>, which you can override with -o=<my staging
directory>
But if you override the staging directory, you will have to specify this
directory when running the build.bat for the installer.
I've detailed the build instructions here:
http://themapguyde.blogspot.com/2009/03/building-mapguide-on-windows-made.html
- Jackie
Kenneth Skovhede, GEOGRAF A/S wrote:
> I just tried a fresh checkout today.
> After building MapGuide, using the "build.bat", I get the folder
> MgDev\Server\bin\Release
> But the "build.bat -a=regen" in the Installer looks for
> ..\MgDev\Release\Server\Bin
> And that second folder is supposed to contain other stuff (like the repo
> admin files).
> Do I have to perform another step to get that special folder prepared?
> Regards, Kenneth Skovhede, GEOGRAF A/S
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/Installer-Automated-build-tp2432681p2433289.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
