[mapguide-internals] Installer: Yeah baby!
Jason Birch
Jason.Birch at nanaimo.ca
Wed Mar 11 21:19:02 EDT 2009
Yes. Funny message :)
I'll try to find time for iis7 install tonight.
----- Original Message -----
From: mapguide-internals-bounces at lists.osgeo.org <mapguide-internals-bounces at lists.osgeo.org>
To: mapguide-internals at lists.osgeo.org <mapguide-internals at lists.osgeo.org>
Sent: Wed Mar 11 17:52:44 2009
Subject: Re: [mapguide-internals] Installer: Yeah baby!
Did you get a IIS6-specific dialog during installation?
- Jackie
Jason Birch wrote:
> Awesome.
> Just ran through the installation on Win2k3.
> - Installed .Net 2.0 and VC redistributables
> - Ran installer, chose IIS, PHP, left the feature tree at defaults,
> rebooted
> - Connected to MapAdmin: no problem
> - Connected to MapAgent: no problem
> - Loaded up /mapguide/fusion/templates/mapguide/standard/index.html : no
> problem
> There are definitely still some issues and need to test different
> configs, but... this is cool!
> Here's what I did to build:
> - Copied FDO 3.4 RC2 into correct locations and installed prereqs as per
> Jackie's blog
> - Modified Mapguide and Installer build.bat to point to local tool
> locations
> - Started my VS2008 command prompt and went to my main SVN directory
> pushd MGDev
> call build.bat -a=build -w=all
> call build.bat -a=install -w=all -o=C:\Staging\
> popd
> pushd maestro
> pushd Maestro
> call "Update RELEASE Environment.bat"
> popd
> call build.bat -a=install -o=C:\Staging\Maestro
> popd
> pushd installer
> call build.bat -a=prepare -web=C:\Staging\WebServerExtensions
> -srv=C:\Staging\Server -maestro=C:\Staging\Maestro
> call build.bat -a=regen -web=C:\Staging\WebServerExtensions
> call build.bat -a=build -web=C:\Staging\WebServerExtensions
> popd
> Jason
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/Installer%3A--Yeah-baby%21-tp2464815p2464861.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
