[mapguide-internals] RE: File versions...
Walt Welton-Lair
walt.welton-lair at autodesk.com
Fri Mar 13 17:32:11 EDT 2009
I think it would be worthwhile to update the major & minor values each release.
There's a freeware tool called StampVer (http://www.elphin.com/products/stampver.html) which can be used to set version information in DLLs / EXEs. But it doesn't work on 64-bit modules.
Walt
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Friday, March 13, 2009 4:59 PM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] File versions...
Hi all,
Looking at the code, the .rc files generally do not reflect the current
MapGuide version number.
Is it worth maintaining these manually to keep in sync with at least the
current release major version?
Is there a utility that can be run post-build to update the file
versions embedded in .dlls (and exes?) to reflect something like the
MapGuide version number + SVN revision? (2.1.0.3728)
Jason
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
