[mapguide-internals] My MSI Install Issues
    Jason Birch
    Jason.Birch at nanaimo.ca
    Mon Mar 16 18:29:28 EDT 2009
Yes, my w2k3 and w2k8 machines are clean vm images.  I'll roll another installer in a bit and try again but I think this one was from about 15 hours ago... after that revision?
----- Original Message -----
From: mapguide-internals-bounces at lists.osgeo.org <mapguide-internals-bounces at lists.osgeo.org>
To: mapguide-internals at lists.osgeo.org <mapguide-internals at lists.osgeo.org>
Sent: Mon Mar 16 15:07:47 2009
Subject: RE: [mapguide-internals] My MSI Install Issues
Was the system bare-bones? The installer was rolling back at the end because
the MFC merge module wasn't included (it was required by the Apache custom
actions), which has since been resolved:
http://trac.osgeo.org/mapguide/changeset/3737
- Jackie
Jason Birch wrote:
> I'm seeing rollbacks too in a recent build of the installer.  Haven't run
> with logging enabled yet, but it looks similar to what you're seeing.
> Jason
> ________________________________
> From: Crispin_at_1Spatial
> Sent: Mon 2009-03-16 11:00 AM
> Subject: [mapguide-internals] My MSI Install Issues
> Got another MSI today but can't get it to install... it rollsback at the
> end
> of the web services file-copy so I have two issues (logs are from the MSI
> install).
>  1) Server Only Install
> Looks like I am missing the service registration element?
> Info 1721. There is a problem with this Windows Installer package. A
> program
> required for this install to complete could not be run. Contact your
> support
> personnel or package vendor. Action: MgServerInstallCA, location:
> C:\Program
> Files\OSGeo\MapGuide Server\bin\mgserver.exe, command: install "MapGuide
> Server 2.1"
>  2) Web Server Extensions (.net Only)
> Gets so close... it's a bit harsh doing a complete rollback if the config
> fails - looks like there are things that try to run and fail even if I
> select to do a manual configuration.
> Action start 10:28:03: InstallFinalize.
> Action ended 10:28:19: InstallFinalize. Return value 3.
> Action ended 10:28:21: INSTALL. Return value 3.
> Action ended 10:28:21: ExecuteAction. Return value 3.
> Action start 10:28:21: FatalError.
> Action ended 10:28:32: FatalError. Return value 2.
> Action ended 10:28:32: INSTALL. Return value 3.
> === Logging stopped: 3/16/2009  10:28:32 ===
> MSI (c) (E4:B4) [10:28:32:168]: Product: MapGuide Open Source 2.1 --
> Configuration failed.
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/Installer%3A--Yeah-baby%21-tp2464815p2488763.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
