[mapguide-internals] Installer - work in progress
Zac Spitzer
zac.spitzer at gmail.com
Tue Mar 17 23:35:20 EDT 2009
on a standard bundled install with this installer on xp sp3 I get
Configuration Exception: /webconfig.ini (twice)
from a mapagent request for a tile
z
On Wed, Mar 18, 2009 at 7:39 AM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> Just an addendum:
> If you run:
> msiexec /i MapGuideOpenSource-2.1.0-Unofficial.msi /l*v log.txt
> It will log the whole process making it easier to diagnose any problems.
> - Jackie
> Jason Birch wrote:
>> Martin at EDSI has graciously placed a recent build of the installer in
>> the following temporary location:
>> http://gis.edsi.com/MapGuideOpenSource-2.1.0-Unofficial.msi
>> This will only be available for a limited time, and should not be
>> broadcast widely so their server doesn't get swamped, but it will give
>> you a chance to try out the new installer if you have been following
>> along but haven't had a chance to build your own yet. The installer
>> still needs considerable testing, especially to ensure that configurable
>> items get set correctly, that all OS / API language combinations work,
>> etc.
>> There are some known issues with IIS7, and if you want to install under
>> IIS7 you'll have to start up a command prompt "as Administrator" and run
>> it like:
>> Also, I thought I had resolved this (patch attached to ticket 911), but
>> Crispin had to manually install the Visual C++ runtime (VS2008 SP1) for
>> the installer to complete successfully.
>> If you run into problems, please update or enter new trac tickets under
>> the Installer component.
>> Thanks,
>> Jason
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> View this message in context: http://n2.nabble.com/Installer---work-in-progress-tp2493651p2493696.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
