[mapguide-internals] More MSI Install Issues
Jackie Ng
jumpinjackie at gmail.com
Fri Mar 20 04:58:19 EDT 2009
I've made some fixes for Java. You need to rebuild your staging area and
regenerate your include files.
Firstly run MgDev\build.bat -a=install -w=all -o=YOURSTAGINGAREA
Then run Installer\build.bat -a=regen
-web=YOURSTAGINGAREA\WebServerExtensions
- Jackie
Crispin_at_1Spatial wrote:
> Folks,
> Just got to SVN sync and my installer won't build anymore... looks like
> there are some hard-coded paths?
> Or are the "source path" references in the error log replaced by the build
> parameters? I have everything on an E:\ drive and no references to
> C:\mg-trunk.
> Crispin
> LINK : warning LNK4199: /DELAYLOAD:OleAcc.dll ignored; no imports found
> from Ol
> eAcc.dll
> E:\Projects\MapGuide\trunk\Installer\Libraries\MapGuide Web
> Extensions\FileIncl
> udes\incWebInfFiles.wxs(30): error LGHT0083: The file with id
> 'file_WEBINFFILES
> _0' and name 'web.xml' could not be found with source path:
> 'C:\mg-trunk\MgDev\
> Release\WebServerExtensions\www\WEB-INF\web.xml'.
> Extensions\FileIncl
> udes\incWebInfFiles.wxs(34): error LGHT0083: The file with id
> 'file_WEBINFFILES
> _1' and name 'vdeukqx2.jar|commons-codec-1.3.jar' could not be found with
> sourc
> e path:
> 'C:\mg-trunk\MgDev\Release\WebServerExtensions\www\WEB-INF\lib\commons-
> codec-1.3.jar'.
> Extensions\FileIncl
> udes\incWebInfFiles.wxs(35): error LGHT0083: The file with id
> 'file_WEBINFFILES
> _2' and name 'szeeycn5.jar|commons-fileupload-1.0.jar' could not be found
> with
> source path:
> mons-fileupload-1.0.jar'.
> Extensions\FileIncl
> udes\incWebInfFiles.wxs(36): error LGHT0083: The file with id
> 'file_WEBINFFILES
> _3' and name 'uuozvvhy.jar|MapGuideApi.jar' could not be found with source
> path
> 'C:\mg-trunk\MgDev\Release\WebServerExtensions\www\WEB-INF\lib\MapGuideApi.ja
> r'.
> [ERROR]: There was an error building the component
> E:\Projects\MapGuide\trunk\Installer>
View this message in context: http://n2.nabble.com/Installer%3A--Yeah-baby%21-tp2464815p2507750.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
