[mapguide-internals] Installer - work in progress
Zac Spitzer
zac.spitzer at gmail.com
Mon Mar 23 19:58:46 EDT 2009
Maestro or the server? it would be great to get rid of this dependancy
and avoid the reboots, it's ok on your own desktops but can be a real pain
on a server.
dev stuff aside, is it worth considering just hardwiring the path in the
app to ..\CSMap\Dictionaries relative from the bin dir?
reboots are so 1990's :)
this also allows multiple installs of versions of mapguide if we
remove this requirement
can someone can explain why this is needed at all?
or does php require this as well?
MS just released a new installer BTW
http://blogs.msdn.com/markbrown/archive/2009/03/18/announcing-web-platform-installer-2-0-beta-and-windows-web-application-gallery.aspx
z
On Tue, Mar 24, 2009 at 10:51 AM, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
> Setting the maestro dictionary path requires the reboot. Because MapGuide runs under the local service, which is already logged in, you have to reboot to get the env var to register.
> I'm not too worried about the reboot requirement; at least the installer tells you that it's required.
> Jason
> -----Original Message-----
> From: Zac Spitzer
> Sent: March-23-09 4:29 PM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] Installer - work in progress
> A complete uninstall and then deleting the left over dirs resolved
> that problem for me...
> what causes the requirement for a reboot out of interest?
> is it the environment vars? if we could avoid the reboot it would be golden :)
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
